LS6 bolt ons + cam numbers
Old Feb 14, 2010 | 08:36 AM
maxspeed96ct's Avatar
Default LS6 bolt ons + cam numbers
05 LS6 cts-v dyno numbers
Finaly got some number I like.
Comp xr281 cam 232/234 .594 112
kooks 1 7/8 catted
DMH cutout
160 stat
powerbond 10% underdrive pulley
ported throttle body
spec 3+ clutch with 22lb flywheel
tune by don at slowhawk
Best run was 409hp 369tq
Im suprised the Tq wasnt closer to 400, im not sure if its the cam or Im just trying to compare my numbers to LS2 cts-v
Check out the vid and the sheet .
The bottom (blue line ) are the numbers from my 220-224 cam
374hp 362 tq
the middle (green line ) is a final fun after tune
405 hp 366 tq
Final and best run (red line) we opened up the cutout
409hp 369tq
video is here http://www.youtube.com/watch?v=gCgsYK86lU0
Old Feb 14, 2010 | 10:32 AM
ScreaminRedZ's Avatar
registered user
Great numbers! Being on a Mustang dyno, you're numbers are probably very close to mine and I have a similar cam, but Trick Flow heads. My torque numbers are low as well. I can't decide whether to try a bigger cam or just keep saving and do the FAST intake and 90mm TB.
Old Feb 14, 2010 | 11:49 AM
VincesSS's Avatar
Probably should have just left the ls6 cam in there..
Seriously though you can't compare dyno numbers, especially mustang dynos.. take it to the track and see how it does there.
Old Feb 14, 2010 | 01:43 PM
No yet, Im still to scared after I blew a differential back in november.
Ive a few things Ive got to do before I hit the track.
Old Feb 14, 2010 | 02:26 PM
registered user
We'll have to get you lined up with a few cars that we know what they trap. That'll give you a pretty good idea.
Old Feb 14, 2010 | 05:15 PM
Slowhawk's Avatar
LS1Tech Sponsor
Car runs very good.Better than I thought it would with a Cam that size.It would probly put out 10hp/10tq more on a dynojet.
Now just have to figure out how to put in a 9" solid axle rear.
Old Feb 14, 2010 | 05:56 PM
hell ya, cant wait to do some more meets this summer.. Im going to have to stick to roll runs though no matter how much **** the evo's and sti's talk.
Don maybe in another year or 2 ill give you a call and see if your up to the challange of dropping in the ford 9"
Old Feb 14, 2010 | 08:58 PM
registered user
Most of the ones I run into are more into rolls than digs. I guess they break parts alot, haha.
Old Feb 15, 2010 | 04:51 AM
itsslow98's Avatar
nice numbers i bet she rolls out. cant wait to see some videos, now all you need is a set of heads.
btw, isnt the cam an XER from comp, not an XR?
Old Feb 15, 2010 | 12:14 PM
santiago's Avatar
ill be running the same headers and 236/238 113 cam .
thanks for putting the your results up
