Dyno Comparison After S60 install
Old Mar 11, 2010 | 04:26 PM
Blackfly's Avatar
Default Dyno Comparison After S60 install
Before Rear@ 125 shot
~545rwhp/512rwtq
After S60 rear w/3.73 & Tru Track carrier @150 shot and new fuel pump
549rwhp/667rwtq
I also posted this in Gears & Axles
https://ls1tech.com/forums/gears-axl...l#post13015754
Just wanted an explanation in "laymen" terms...what does it all mean compared to my previous dyno
I built this car for Auto Course/ highway runs
Old Mar 11, 2010 | 04:42 PM
396D1SS's Avatar
its just torque from the shot, the higher the shot the torque usually up's more
Old Mar 11, 2010 | 08:00 PM
03 BUSA's Avatar
You really need to dyno motor to motor to know the real loss/gain imo.
Old Mar 11, 2010 | 08:37 PM
SimRacer1's Avatar
upgrding to an s60 rear and going from a shot of 125 to a shot of 150 gave you like an extra 150 lb ft of torque??? dont understand how that works
Old Mar 12, 2010 | 10:34 AM
FrankSSCamaro's Avatar
the torque, although expected, should not bump THAT much. all in all good numbers. how does it feel in the car?
Old Mar 12, 2010 | 11:01 AM
Blackfly's Avatar
NO. I upgraded the Rear AND added an addtional 25 shot.
The Tq. rating is not from the No2 but it does play a small factor. I'm about to upload the Dyno with the stock rear and the exact same setup other than the fact it had a 125 shot.
When I drop the hammer In third on the highway, the tires spin and the *** tries to come around, it then digs in and drops...and awaayyy we go!
Correction!!! I just remembered I upgraded my fuel pump on the newer Dyno run I dont think that has alot to do with the Tq gains though.
Old Mar 12, 2010 | 01:02 PM
willystyle438's Avatar
Nice #'s.........
Pyle Bros. just installed my 12 Bolt last week.
Old Mar 12, 2010 | 01:13 PM
chavez885's Avatar
Maybe originally it was needing more fuel
Nice numbers
Old Mar 12, 2010 | 03:27 PM
chrs1313's Avatar
so the rear ate up around 21rwhp...don't worry about the tq numbers so much...like an a4 unlocked on the dyno...just inflated
Old Mar 13, 2010 | 01:22 AM
quik01ss's Avatar
basically its not a rear comparison of motor with stock rear then going to s60 rear with same gearing soo you added +25hp to your shot and made or added more than what the s60 would take away ..i think not a comparison at all just new numbers with a few more modifications
Old Mar 15, 2010 | 08:11 AM
Blackfly's Avatar
Good point. I did'nt think of that. I forgot that I added UMI Front & Rear bars, adj. Torque arm and loop when I installed rear as well which would also contribute to the increased Tq. rating. So these are just "new #'s"
Old Mar 15, 2010 | 10:32 AM
Stang's Bane's Avatar
I am failing to understand how changing the suspension components will change the torque reading, unless you were spinning on the dyno before and you think the new stuff is making it hook.
Old Mar 15, 2010 | 02:09 PM
Blackfly's Avatar
Hmmm...I thought the suspension (Torque Arm and shorter Drive shaft) would help transfer the power to the rear better.
Something is very odd...Im not sure why the Tq. jumped as high as it did.
Im going to get it another Dyno pull on the 28th.
Old Mar 15, 2010 | 02:33 PM
If the tires were not spinning, those components would make no difference whatsoever.
All the dyno measures is how fast that roller accelerates.
Old Mar 15, 2010 | 03:31 PM
Slowhawk's Avatar
LS1Tech Sponsor
I agree.You have no comparison on switching the rear.
