Tony Mamo Recipe
Old Mar 26, 2010 | 01:27 PM
corvet786c's Avatar
Originally Posted by VeTTeMaNC486
I didnt mean any negativity by my comment, just pointing it out. Small, good flowing runner heads and relatively small cam, I would expect more low end.
What kinda numbers do ya get at the track?
No man its cool. With these tires mid to low 12's, with drags and a new 12 bolt mid to high 11's
Old Mar 26, 2010 | 01:55 PM
TS99V6's Avatar
Originally Posted by smok'nZ
looks expensive
My out of pocket is very low. I'm a web designer so I've bartered my work for most of those parts.
Old Mar 26, 2010 | 03:37 PM
matt1289's Avatar
I ended up with a **** load of low end torque without milling and a smaller cam dynos are tuning tools that all there is to it. I finally get to take it to the track today in about 3 hours I can't wait. I still have a ls6 intake.
Old Apr 17, 2010 | 05:57 PM
02SOMWS6's Avatar
My old set up put down 452 rwhp and 402 rwtq threw a 12 bolt with 4.33 gears
-that was the same cam on a 110 centerline and a set of factory 241 heads worked over with bigger valves and decked 30 along with a Mamo ported Fast 90. It should make 450rwhp or better
Old Apr 17, 2010 | 06:23 PM
mike c.'s Avatar
I made 463hp 414tq with afr heads on a lil 346ci ls1. I had a non-ported fast and no e.w.p. I could of made more with the set up. I ran 11.1's in a 3,700lbs car. Good luck to ya.
Old Apr 18, 2010 | 12:59 AM
fastmatt98's Avatar
I got right at 460rwhp out of my set up so you should be around that. Only thing I wish is that it had more torque.
Old Apr 18, 2010 | 01:27 AM
Squirts11's Avatar
While that 224/228 cam is the one Tony used to make 500rwhp, why don't you go a bit bigger (since you currently are running a very similar 224/224 cam)? Even with the heads milled to 62cc and a .040 gasket, PTV should be large enough to allow a cam with more potential. Even a 228/228 would have perfect manners with a decent tune.
Old Apr 26, 2010 | 10:16 PM
zstripper2k's Avatar
You have all the parts minus the cam of the Patrick G 500rwhp 347. So if you get the right cam you should be there. Worth the little extra for the custom cam looking at that pile of money in the picture. My guess is in the range of 4K.
Old Apr 27, 2010 | 12:42 PM
mjcotroneo's Avatar
whose doing all the work? if you want it done soon. let me know ill do it for you. pm me or call me 214-683-1509
Old Apr 27, 2010 | 01:53 PM
TS99V6's Avatar
I'll be doing the install myself. Thanks for the offer though.
Old Apr 27, 2010 | 02:10 PM
jester ls1's Avatar
Originally Posted by corvet786c
Dont get me wrong my car rocks 3500 rpms, this car throws you back.
If your lookin for dyno numbers get those heads messaged by tony.
Mine are stock too out of the box. If I had to do it all over again I would go with something else a lil cheaper. JMO
The PRC 5.3 2.5 for $1100.00 a pair are hard to beet made 430/391 with the below set up on motor. Just the heads made 50 HP and 40 TQ!
Old May 4, 2010 | 11:39 AM
  #32
TS99V6's Avatar
Ok I had Pat G spec me out a cam. Looks like I'll be going with a 226/230 .598”/.600” 113LSA +1.
Old May 4, 2010 | 01:27 PM
  #33
smok'nZ's Avatar
MASS seller approved
cool now when you gonna install that stuff?
Old May 4, 2010 | 01:37 PM
  #34
TS99V6's Avatar
Have to order a couple more things first. I would say at least by july if not sooner.
Old May 4, 2010 | 09:37 PM
  #35
smok'nZ's Avatar
damm thats a long time what are you missing a shortblock seriously gaskets,bolts etc??
Old May 4, 2010 | 09:57 PM
  #36
TS99V6's Avatar
I'm in no hurry. Still need to order the cam, pushrods, katech timing chain and get my fast and lid smoothed and painted. I have everything else.
Old Jun 9, 2010 | 12:46 PM
  #37
corvet786c's Avatar
Hey man its been awhile, just wanted to know what was the progress on your AFR build??
Old Jun 9, 2010 | 02:28 PM
  #38
TS99V6's Avatar
Nothing new. I had to put a hold on the build for a while. Should be back on track in the next couple of months.
Old Jun 9, 2010 | 02:38 PM
  #39
ds98formula's Avatar
Looks like it will be a killer setup
Old Jun 10, 2010 | 06:31 AM
  #40
Michael02hawk's Avatar
There are 3 magic ingredients in Tony Mamo's recipe:
1. The little details taken into account when he builds an engine.
2. The hand porting he does to a FAST intake.
3. The hand porting he does to the AFR heads.
Unless your having Tony build your engine, you cant take advantage of #1,
You already have your FAST mamofied!
I'd recommend sending your heads in for the same finish touch before installing them.
I had Tony port my AFR 205 heads 2 years ago, I gained 11 rwhp and 11 rwtq top end, but gained 25 rwhp under the curve!
