Cam only M6 9inch car
Old Mar 29, 2010 | 11:08 PM
Grn4fbody's Avatar
Default Cam only M6 9inch car
Headers,Ported TB,Tune and a Custom cam threw a M6 and a 9inch
Thought I'd get some base numbers before the spray
Old Mar 30, 2010 | 12:22 PM
smok'nZ's Avatar
MASS seller approved
damm thats some nice tq what cam is that?
Old Mar 30, 2010 | 12:26 PM
blubyu02's Avatar
i did 386/379 before my 9 inch, and ls6 intake im interested in seeing what i can do now with the 9 inch, those are some good looking numbers you got. what size shot you going to hit it with?
Old Mar 30, 2010 | 05:02 PM
Grn4fbody's Avatar
Custom grind,Spec'ed out by Pat G
9 inch's robs some power but IMO there worth it. and 100 shot for now untill I get a pump.
Old Mar 30, 2010 | 08:35 PM
lilbuddy1587's Avatar
SAE numbers are?
Old Mar 30, 2010 | 11:25 PM
Grn4fbody's Avatar
Originally Posted by lilbuddy1587
SAE numbers are?
The guy's gonna PM me tomorrow with the SAE numbers
Old Mar 31, 2010 | 05:10 AM
Nitroused383's Avatar
If you look at the correction factors how does that temperature jump from 59 degrees to 64 degrees in a matter of 10 minutes? I think someone was tampering with the correction factors, you will lose around 5-8 hp with SAE numbers.
Old Apr 6, 2010 | 08:40 AM
firefighter813x's Avatar
Busted! jk
Old Apr 7, 2010 | 05:21 PM
KCFormula's Avatar
STD is usually higher than SAE, which is what most people use. Which may explain why the temp is also changed so much.
