dyno gains with kooks and ported fast
Old Apr 25, 2010 | 10:06 PM
TXsilverado's Avatar
Default dyno gains with kooks and ported fast
the run down.
140,000 mile old stock bottom end LS1. patriot stage 2 ls6 heads unmilled with .040 gasket. patric G 231/239 .617/.623 111+2 cam. ported fast 90mm with NW throttle body. underdrive pulley, intake, kooks 1 1 7/8 stepped to 2" headers with true dual 3" with x and bullets.
dyno was done in third locked through 4.10 gears and 305/45-18 tires(29" tires)
only changes from previous dyno is kooks headers with true dual over pacesetters and single 3"...and a ported fast 90mm instead of the LS6 with ported stock throttle body. same dyno, and worse weather this time.
the numbers seem great, but the track doesnt agree sorry about the cell phone quality graphs
down low gains:
up top gains:
Old Apr 25, 2010 | 10:47 PM
smok'nZ's Avatar
MASS seller approved
great gains
Old Apr 25, 2010 | 11:32 PM
MauriSSio's Avatar
what correction factor? is that STD?
Old Apr 25, 2010 | 11:37 PM
yes the correction is in STD (like it says in the top right). i posted the STD numbers because they printed them with the low HP/TQ gains and the High HP/TQ gains.
the SAE numbers of the motor was 430.13 HP and 396.10 tq.
Old Apr 25, 2010 | 11:38 PM
anyone else think it's weird that the curve of the ported 90mm followed the ls6 intake? i figured it would pull away after 6500 RPM?????
Old Apr 26, 2010 | 12:42 AM
Sudz's Avatar
I think its weird someone spun your 140k stock motor to 7500rpm, what the hell is that
Old Apr 26, 2010 | 12:57 AM
Johnnystock's Avatar
it did the same for me..
ouch!!
Old Apr 26, 2010 | 07:28 AM
i told him to. been shifting 6900 to 7100 for about 5 years now. now i know i dont need to go any farther than 68 or 6900. and the rev limiter is at 7300. i told him to go until it touched the limiter.
Old Apr 26, 2010 | 07:52 AM
ScreaminRedZ's Avatar
registered user
Nice gains! No improvement at the track? Due to weather you think?
Old Apr 26, 2010 | 09:41 AM
possibly weather, possibly gearing. running 4.10 gears right now...thinking about some 4.56 gears. race weight of 4500 lbs.
last time at the track my shiftpoint showed to go from 7190 to 5358 on the 2-3 shift and i crossed the trapps at 5200rpm locked...out of the power. 4.56 should put me across the line around 5800rpm locked. then i have the nitrous that i have to worry about running out of gear on.
Old Apr 26, 2010 | 11:00 AM
SAPS's Avatar
What was your track results. 60 ft & 1320 et/mph?
Old Apr 26, 2010 | 11:09 AM
12.40@108 N/A on the current setup.
60' is 1.67 to 1.72 N/A. the truck has 2 nitrous kits on it too but i havent flipped the switch in a while.
my best track time was 12.19@110 N/A with a 1.69 60'. that was with the 226/226 112+4 cam, ls6 manifold and pacesetter/single 3" exhaust (ORY). it was a COLD night though. -1500 DA or some crazy crap like that.
the dyno numbers at that time were around 390 tq and 410 HP uncorrected.
even still, i dont see why i dont trap a higher MPH. from 5500+ i am making more power everywhere in the graph. not just peak. 4.56 gear should put me higher into my power band though. hopefully i can gain in the 60' and mph dept with a taller gear.
Old Apr 26, 2010 | 11:24 AM
Patrick G's Avatar
LS1 Tech Administrator
You answered your own question. If you don't make big gains over your old cam until 5500 rpm (and you're only trapping at 5200 rpm), you're not going to see the big gains. Honestly, I think you'll go quicker by shifting closer to 6700-6800 rpm and keeping the converter unlocked. This way, you'll allow the torque converter stator to multiply torque a little longer and slip you to your powerband a little faster. In my experience, locking the torque converter only helps if you're above peak power by the time you trap, not way before your peak.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 26, 2010 | 11:26 AM
i tried different lock points and going completely unlocked anywhere from 6800rpm to 7200 rpm...they all made the same times and MPH. it "FEELS" much better locked though. the track says its the same though lol.
unlocked i trap 108 MPH at 5800 RPM.
i have never dyno'd with the nitrous though. ive heard that it makes the peak power and torque pull back? is there any truth to this? like, i peak around 6500 right now N/A, would i peak at 6200 with a 200 shot?
Old Apr 26, 2010 | 12:18 PM
SAPS's Avatar
what does the truck weigh?
Old Apr 26, 2010 | 12:19 PM
4500ish race weight.
Old Apr 26, 2010 | 08:50 PM
dlt76028's Avatar
12 Second Truck Club
Whats with the weird dip around 4800rpm? Is it going too lean or rich there?
Nice #'s though Stew
Old Apr 26, 2010 | 09:17 PM
66deuce's Avatar
have you logged it running down the track?
in addition to the advice that Pat gave,i would log it to check for timing/fueling issues..or maybe converter issues
sometimes you don't get the same power at the track you got when dynoed..don't ask me how i know
Old Apr 27, 2010 | 01:16 AM
Wheatley's Avatar
Truck Sponsor
Nope,air fuel is fine.We added alittle fuel and pulled alittle,that made it worse.With a few more degrees of spark it helped it but anymore and it made even worse again.So apparently it was best where it is at.
Stuart and I will be spending more time on the dyno shortly I am very sure.
Old Apr 27, 2010 | 09:27 AM
yeah, we have dyno logs, track logs, street logs, and logs of logs lol. this was the first time on the dyno. i was surprised how close charlie had it nailed down with a street tune. we squeezed a tiny bit more out of it with 1* less timing but not enough to see it on the track IMO. every time we tried something it lost power. we only got to play with the tune for 3 pulls.
