building mild ls2, difference on dyno or non dyno tuning
Old Apr 25, 2010 | 10:57 PM
josh93z38's Avatar
Default building mild ls2, difference on dyno or non dyno tuning
i am relatively new to the gen. IV lsx engines and was wondering if putting a cam (291/311 573/558 on 109 LSA) and ls6 intake with matching throttle body, and longtubes would require a dyno tune or if i could just get it tuned without using a dyno. or what the gains might be with using a dyno over not using a dyno. thanks.
Old Apr 26, 2010 | 12:22 PM
SAPS's Avatar
did i read that correctly....291/311 duration cam?
Old Apr 26, 2010 | 02:28 PM
got-a-ls1's Avatar
probably .006 lift duration numbers instead of .050?
Old Apr 26, 2010 | 07:00 PM
josh93z38's Avatar
Default .
yea the .050 #s are 235/249, its the comp cams big ***** thumpr 291, im kinda goin for sound, but if that is gonna compromise any performance then i will go with a different one. thats something ive been questioning as well. i want something driveable.
Old Apr 26, 2010 | 07:20 PM
Orange Juice's Avatar
Someone will have to alter the tune for you no matter which cam you get. Do you have a builder in mind, they will direct you to a cam choice. Is your car an automatic, M6. what are the rear gears.
Spend some time reading this forum, keep a notepad by your computer and take notes. There is alot to learn.
Old Apr 26, 2010 | 07:59 PM
josh93z38's Avatar
i have a 2000 firehawk, im swapping an lq9 into it, cam, upgraded valvetrain on the stock 317 heads, ls6 intake manifold and throttle body, headers, and looking for a tune, my end goal is about 450 rwhp and myself and a buddy of mine are gonna be doing the work. automatic 4l60e with 3600 stall, stock 3.42 gears. like i said, i want that old school sound but im not willing to sacrifice any performance or drivability for it.
Old Apr 27, 2010 | 06:37 AM
BLK02WS6's Avatar
You will definitely need a tune with your combination/goals...
