l92 bottom end with prc 5.3 stage 2.5 heads
car is a 2000 trans am m6 first time on the dyno..with a mail order tune
mustang dyno
l92 stock bottom end with katech rod bolts
prc 5.3 stage 2.5 heads (off my old ls1) around 11.4:1
patrick g cam 235/243 on 111
pace setter headers
new texas speed y pipe
magnaflow cat back
fast 92 intake
nw 92 tbody
moser 12 bolt with 4.10s
stock maf
445.4 whp at 6420 rpm
409.5 torque at 4650 rpm
mustang dyno
pace setter headers
magnaflow cat back
fast 92 intake
nw 92 tbody
stock maf
LS1Tech Premium Sponsor
Nice numbers! Any plans to get to the track any time soon?
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
ya the car has been down for a year. last summer the old ls1 quit on me right around this time. so i saved some money and landed the l92 short block from a buddy that worked at a gm dealer i think it was out of a 08 denali that had dropped a intake valve and messed up the piston so i just got a factory replacement piston and basically took everything off the ls1 and swapped if over to the l92 minus the cam. i finished the swap the night before the chevy fest event up in new england dragway. ran a bunch of shitty 12.3's but at 119 120ish horrible 60 foots. went up again a month later did an 11.8 at almost 123 (car weighs just over 3700 pounds) and i went around again for my 4th run and the stock torque arm bent causing the driveshaft to blow up into a million pieces. so i got a umi ta and pst 3.5" drive shaft in this winter but havent been up yet. im prob gona bring it to slowhawk to get tuned before i do and im getting some 15 wheels with bias ply tires im sick of 1.8 60's.
as far as the maf do they really hold the power gains back...if its that big of a deal ill prob have to get one. any guess on wat a bigger maf and real tune mite get me?
im gona try to get the graph up to its a good looking curve. ps this was an all audi dyno day my bro has an 04 s4 and they needed a spot filled so it was funny seeing these kids reactions
LS1 Tech Administrator
Strong power. The stock MAF can become a restriction in some of the more stout heads/cam combos. It would help if you could log your MAP kPA and see if your motor is pulling much of a vacuum at WOT. Any kind of vacuum at WOT indicates intake restriction of some sort. Could be the manifold or TB, but more likely it's in front of the TB. Replace the MAF with a 3.5" straight pipe and see if your power increases. Of course, you'll need to be speed density tuned for that. Again, strong power.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
P.s Patrick G i was wondering if u specd cams for gen 1 chevy small blocks also..i have a gm performance parts 350 ho going in a regal and need a good cam
what do you mean what about the heads? on tsps site they say i think 312cfm on the intake at 600 ivew never had them bench flowed. i know they may be a small head for the application but i built it out of all the parts off my old ls1 plus patricks cam spec. im sure a tfs or prc aftermarket casted head would make more power but i dont wana spend the money right now. i have no interest in putting l92 heads on it either
Oh yea I was just wondering what those heads flow just for my own knowledge. Good set up I was actually looking into these heads when I end up doing my engine. Thanks for the info
any time but like paint it black said the flow numbers are def not everything. im sure theres threads in here that have been beaten to death over this same subject.
i like these 5.3 heads for the money they do well. im just wondering what a nice set of prc 227 or tfs 225 would do for stock bttom end l92
i should have a new graph with a ftp 104mm lid tsp 100 maf and a slowhawk tune in the upcoming month just waiting for the parts to come in.
