looking for 383 ci numbers
Old May 17, 2010 | 06:57 PM
1bigcam's Avatar
Default looking for 383 ci numbers
iam in the middle of building a 383 ls1 and am looking to see what kind of power i should expect.
383 ls1 11.5-1
tsp 2.5 ls6 heads
tsp 240-244 610 612 lift on a 113 and a 111 icl
fast 102mm with 90mm tb
shorty hooker headers 2.5 exhaust with x pipe and dynomax bullets
and last thing up to a 200 shot of the good stuff lol
thanks mike
Old May 17, 2010 | 07:10 PM
SSdreamz's Avatar
hey Lake, the numbers are in my sig, you can see on my graph that the LS6 is choking it out up top though
Old May 17, 2010 | 09:33 PM
1bigcam's Avatar
thanks, i would like to do 450 whp na with the 4l60e
Old May 18, 2010 | 07:28 AM
Hemi Killer's Avatar
14 Second Truck Club
I made 394/408 locked in 3rd gear with my cutouts open. I think my cam might be advanced +8 instead of +4 like it's supposed to be though. The guy that built the motor was supposed to have fixed it, but it peaks at 5500...
Old May 19, 2010 | 06:47 PM
52172's Avatar
why are you running shorties?? That 383 is gonna need to breath! You got the big old intake you need the exhaust to go with it...
Old May 19, 2010 | 09:19 PM
1bigcam's Avatar
the motor will be in a 95 miata and they dont make long tubes yet
Old May 19, 2010 | 09:49 PM
wantsum410's Avatar
Default 383
One of Tony Mamos 383'S put down 540 rwh...N/A.I am not 100% but I think it was with a set of the 205 AFR's.Somebody correct me if that is not rt. Do a search for 383 engine dyno results....Alot of good info!!!Around 9/25/05.
Old May 19, 2010 | 10:36 PM
annil8r1983's Avatar
Default should be potent
People on here for some reason think I have no idea what I'm talking about so take it how it is. Your dynamic compression Is gonna be a little high 26-27* timing at most with about 12.7 afr. You have a decent intake for torque but it doesn't have the plenum volume to keep up with the tb and heads. That combo should peak about 6.5k. Should make atleast 480rwhp with a locked converter depending on its efficiency. The shortys will only slightly effect torque unless there smaller than 1 3/4. All in all you should be satisfied but your drivetrain will not like you!
Old May 26, 2010 | 09:35 PM
1bigcam's Avatar
thanks for the info, driveline should hold up it has a ford 8.8 and the axles are rated at 650whp, my goal is 450 whp with the 3600 stall, i think the headers are 1-5/8 but not 100% on that
Old May 26, 2010 | 10:29 PM
rpmauto's Avatar
I had those heads on my 402, good heads. But not enough for what I wanted. Like with all things some people make good #s others dont. At any rate that thing will scream in a little car like that.
Old May 26, 2010 | 11:16 PM
1989GTA's Avatar
"The shortys will only slightly effect torque unless there smaller than 1 3/4."
That has been my experience as well. Above peak torque there is not much to chose from. Below peak torque the long tubes have an advantage.
Old Aug 8, 2010 | 08:48 AM
Honda Nick's Avatar
digging up an old thread, here are my 383 numbers. PRC 215 heads, Torquer 3 cam, FAST 90 setup, 1.75 inch headers, built RPM transmission and differential. This car is very, very easy to drive.
Old Aug 8, 2010 | 09:09 AM
butler's Avatar
through a 5000 stall 470 rwhp and 380 torque. turbo 350.
Old Aug 9, 2010 | 04:49 PM
WKMCD's Avatar
My friend ALOHAC5 on CF made 513RHWP running a Futral cam around 239-244 in his 383. That was with AFR 205's and a 90/90 setup. Unfortunately, he just took the main and rod bearing out on that build. Fortunately, VA Speed is build him a 403.
