506hp ls1 383 Edelbrock RPM Xtreme heads
I thought I would post this dyno since you do not see much info on these heads. Engine set up is tsp 233/239 cam, 78mm fast intake and throttle body, welded and ported flowtech headers, ported factory maf, 3" to 4" y pipe with 4" cutout. Edelbrock heads were also taken apart and cleaned up with sanding roll as the heads are quite rough in areas where cnc meats the cast areas.
I've seen a lot of these graphs lately and could be wrong but I thought that the HP and Torqe should always cross at 5250rpm. No matter what. On this graph they cross past 5700rpm. Whats with that?
