My LSX
Old Jul 1, 2010 | 06:15 PM
barkingspud's Avatar
Default My LSX
For your perusal and comment. Superflo Dyno results. Old but I've just gotten around to analyzing the data to start optimizing the motor before track tuning.
LSX 9.25" Deck
4.2" bore
4.125" Stroke
Ross -15.5cc Custom Pistons
ETP C5R 265 Heads
12:1
Beck intake
105mm TB
Don Bailey Monster Cam (inch lift)
Jesel J2K 1.8:1 Shaft Rockers
ARE Dry Sump
Old Jul 3, 2010 | 02:19 PM
Stage7's Avatar
Sick motor...solid roller I presume?
Old Jul 3, 2010 | 02:43 PM
Engine_HP's Avatar
strong numbers, u must be happy and i must be .
Old Jul 3, 2010 | 03:39 PM
Thanks! I can't seem to find any way to optimize this motor any further. It's met my goals 100% and it's not even in the car yet! LOL... Can't wait to get it on the track.
Old Jul 3, 2010 | 03:45 PM
DBN's Avatar
DBN
Great dyno numbers. I would like to see some pictures of the engine.
Old Jul 3, 2010 | 04:13 PM
Firehawk441's Avatar
Best of luck with it...
Old Jul 3, 2010 | 04:20 PM
LOL...It's pretty typical and in fact, downright plain. The headers pictured are not correct. I'm having custom 2.25" ones made up. The direct port is a Nitro Dave work of art. This has been a long road so far. The motor pic is before I had the front plate fitted properly. Here is a link to the chassis build:
http://www.alstonracing.com/Gallery/GTO/index.html
Old Jul 3, 2010 | 04:41 PM
ATVracr's Avatar
Comes out to 457 cubes.
Pretty stout numbers, get it in the car and spray that bitch !!
Old Jul 3, 2010 | 04:44 PM
LOL! That's the plan my friend! starting with a 500 shot and going up from there!
Old Jul 3, 2010 | 04:59 PM
ATVracr's Avatar
Is this a outlaw 10.5 car?
Starting with 500 Damn ! We hope to work our way up to that with our tall deck motor. If ours doesnt make over 900hp N/A I'll be disappointed.
Old Jul 3, 2010 | 05:09 PM
Believe it or not, it doesn't fit in any specific class. This is a fun car for me although I'm planning on racing in whatever series I can get into. The IMSM heads up stuff looks good so, I'll probably start there. This motor was designed from the ground up (like yours) for a TON of nitrous. 500 was designed as the starting point although I don't expect to go over 700-800....
As far as tires...Starting with 31x16.5x15 ET Streets on a 15x14 wheel. Not going to spray the first season. Then, I'll probably go up a size when I spray. I'm sure you'll make 900 HP no problem.
Old Jul 3, 2010 | 06:01 PM
Two direct ports and a plate?
Old Jul 3, 2010 | 06:07 PM
Yep..Dave made the plate on a whim. Not sure I'll use it unless I go over 800...
Old Jul 3, 2010 | 06:30 PM
Best of luck with it. Are you close to running it yet?
Old Jul 3, 2010 | 06:36 PM
LOL...Motor was done the beginning of this year. The car...Well, that's another story. It should be ready before the end of this season...I hope. this started almost 4 years ago as a simple project to build a forger LSX with a Procharger and spray and here I am 4 years later with this. Have a look at the link I have in the thread. It's like a boat that I keep pouring more and more money into. The good thing is, I'm actually getting close.
Old Jul 3, 2010 | 11:21 PM
OUTLAWZ RACING's Avatar
500 shot........
Old Jul 4, 2010 | 10:03 AM
Originally Posted by OUTLAWZ RACING
500 shot........
Yes indeedy...
Old Jul 4, 2010 | 07:33 PM
UGotBeaT's Avatar
Looks good! Why only 12:1?
Old Jul 5, 2010 | 10:14 AM
Didn't want to mess with the heads and reduce the size of the chambers. Been messing around with the design a bit (with EAP) and haven't seen any real benefit with higher compression given the entire combination.
Old Jul 5, 2010 | 01:48 PM
DBN's Avatar
DBN
What size headers?
