C5 Corvette: LS1 w/ Bolt-ons (automatic) TDC Tuned
In theory, best torque @ 12.5 AFR
best power @13 AFR
In my car for example I gain 2rwhp between 12.6 AFR and 13.
13 AFR is for my bragging internet dyno sheet
12.6 is for real life and road races![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
You have to tune the MAF table and VE table to match the commanded afr and the real AFR. (ie 14.63 AFR in closed loop)
Then there is a PE table (Power Enrichissement table) to adjust WOT setting (ie 14.63 / the PE table value for a rpm range). You can play with the PE table to trick the wot value. That what is about the predator and the bad/in-a-hurry tuners. (aka PE rapping)
With PE rapping you can have a good WOT dyno ... but transitions will suck and are potentially dangerous for the engine
best power @13 AFR
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I think the predator handheld is a great tool for minor bold on (intake/catback), everyone can use it, that's great !
But that's definitely a tool for pro tuners ...
Last week, I copy / paste a tune from my car. (same mod same year : 99 Corvette C5, ARH 1/3 -4 headers (with a wideband), borla catback, callayway honker intake, 28.8 injectors, 85mm MAF. I was 12.8 AFR @WOT ... and my friend 13.4 and 6 knock retard degree !!!) I don't trust canned tunes.
LS1Tech Sponsor
best power @13 AFR
best power @13 AFR
I was looking at it on your website. I'm currently looking for a tool to tune Chrysler cars. I think I have to try it ! do you have demo/trial of your software ? Can I plug my wideband to it ? Can you scan with your CMR ?
LS1Tech Sponsor
The Trinity handheld has 2 analog inputs for logging a WB along with OBDII data, and we offer free logging software, check it out, there are a few sample logs in there:
Dataviewer
Just came back to this after posting... These a/f ratios is what the car liked. Yes, richer will sometimes yield a slight increase in peak torque and 13-13.5 will generally yield slightly more power.
The reason I posted the chart with 2 different smoothing levels was simply to show that it was not knocking. Yes, knock can be easily seen on dynojet charts assuming the smoothing is turned down and this is not knock in any way, shape, or form. The slight turbulence at 5.5k rpms is a flow restriction on the intake side. Basically there is not enough back pressure in relation to the amount of air in the intake side. A vavaram intake would remedy this for the most part by allowing more air in which in turns helps balance the relation between intake flow and exhaust flow.
To Brice, it never hurts to ask before making assumptions. To tune a predator, we have 2 options since we are not Diablosport dealers. We can either tune this setup with HP Tuners or SCT since we are SCT dealers.
Once done, we can pull the tune off the ECU with the Diablosport so there would be no need for the customer to buy any other programmer.
If we tuned it with an SCT handheld then we would simply plug the Dsport unit in after tuning is complete on the SCT unit and then pull the final tune from the ECU. Then we would return the car back to stock with the SCT unit so we can use the SCT unit on another car. Then we would load the tune back through the Diablosport unit. I hope I didn't loose you there. In reality, we use HP Tuners on GM setups since it doesn't cost us anything at this point and the procedure would be the same as far as pulling the tune with a Diablosport unit, minus the whole revert back to stock thing.
