Videos Added!!! Mustang Dyno, TSP 233/239, Huge Converter & 7,000 RPMs
Really!? I was expecting 15 to 20 hp loss on my car but my tuner told me that it only lost 8 hp which suprised us both and he has no reason to lie.
I will be re dynoing for the hell of it some point and I will dyno locked vs unlocked to confirm.
Wow, let me make sure I am understanding this. Your car lost power with the converter locked? I have always thought that locked ALWAYS picks up some power/tq because it eliminates all slipping. The person doing the dyno for me said locked would have added at least 15RWHP, if not more.
Thanks for your input.
Why not turn it to 7,000? If it's making good power up there why not find out where it falls off? If we would have only taken the car to 6,600 rpms, we wouldn't really know what power the car makes. The first run we went to 6,800 and it was showing the power still climbing, so we took it to 7,000. I have the rev limiter set at 7,000, shift points at 6,700.
I say spin the motor til power drops off or for stock rod bolts set the limiter at 7000rpm. With a cam in the 232+ duration range I think it would almost be a sin to not spin to 7000rpm.
1 Post
What makes you say to much converter? I'm not saying I totally disagree with you. Since you said it, you must base your thoughts on something?
As far as the converter, I agree. It is a little to big based on my 10 bolt and the tires I have. Although, the 315s stick pretty good from a low mph roll. It is flashing the converter from a dead stop that they can't handle. 1st & 2nd go up in smoke if I hit it hard from a stop.
I was told and read so much about needing a big converter with the cam I was installing. I think I could back it down to about a 3,800 and a tighter STR. That would probably pick me up some HP and TQ.
Your thoughts?
It would be interesting to get a comparison of several cars on the same dyno. I know of one other car that went on the same dyno, similar setup to mine except they were running a smaller converter, a 3,400 and ran the car with the converter locked-up . That car put down 425/RWHP & 343/RWTQ.
So it may just be the dyno that reads a little on the low side.
#35
unfortunately no, i have a crappy rear end and tracks too far. id estimate around 11.40 @ 120 MPH w/ 3650 race weight + 410 RWHP unlocked.
your car should come out of the hole nasty w that 4400 vig
#36
Not sure what happened with the rear gears but they were setup WAY to shallow and are ear piercingly loud.
I wish I had the money to put a 9" and some sticky tires on the car. I would love to see how it would leave on a full flash off the line dead hooking
Right now I have to preload the rear at the track and bring the car to about 2,000 and come off the line easy. On the street I make sure I am from a low roll if I am going to jump on it.
Dead Hook = Dead Rearend!!!
#39
I agree with your statement about shift points. Why push it to the max RPM/Power to shift. Not much to be gained between 6,700 shift point and the 7,000 redline. In addition, need to take into account shift extension.
Your thoughts?
Your thoughts?
#40
I may toss the car on a dynojet just to see what the difference is before making any changes. I will also get it out to the track before the change is made. With this converter I think 1.4s would be possible with a sticky tire. The problem is would the 10 bolt last? I will take it easy at the track until the last couple runs of the night then drop the hammer & see if it holds. The only problem is I am going to the track on a private track rental day on 8/13 from 9am-3pm (Friday the 13th). I am a little superstitious so we will see what happens.
I shouldn't be so down on Friday the 13th since I was born on one
