Does this sound about right for a 408?
Old Aug 24, 2010 | 07:56 AM
slow trap's Avatar
the 1 7/8 headers and ported 90/90 isn't holding it back much at all imo. i'd try a different dyno and hit the track also .maybe start shifting around 6600 or so and raise/lower it for best results. just my uneducated $.02 though.
Old Aug 24, 2010 | 11:05 AM
WSsick's Avatar
Run it at the track and see where you are at. The dyno is just a tool, and I wouldn't be upset with 508 on a Mustang dyno with that rear end setup.
Old Aug 24, 2010 | 07:17 PM
99LSS1's Avatar
Originally Posted by gmmusclecarman
What about the victor jr. intake? I was told by the shop that no FAST intake setup would flow enough air to hit 7200 rpms. Not to mention the FAST intakes are very expensive.
Well, I can tell you this is BS!!! My 402, with a 90/90 set-up was still making close to 430@ 7200 RPM. I made 461 through an A-4, 3600 Yank, M-9. LS6 2.5 heads, 1 3/4 LT's and a Catted Y. My first pass on this set-up was an 11.17@ 121mph... Pretty sure we will get her in the 10's as soon as we get the Trans fixed.. 3rd gear clutches slipping. I would not be disapointed with your #'s at all.
Old Aug 26, 2010 | 09:36 AM
jimbob's Avatar
Duggie...I think you need to change your sig to PT instead of SS..And really you have a 4800 stall now against your stroker
Old Aug 28, 2010 | 10:26 AM
Cheatin' Chad's Avatar
I've seen similar numbers with less heads and cam. They were on a Mustang as well. I think the numbers are a bit on the low side. Never know though. Different dynos are hard to compare.
