Fast 102 Results Dissapointed
.460 rwhp is very impressive with a mild cam and 243 heads,man. I guess the 102 Intake helps out big time with the right combo put together. Any track times with this set up ?
The car is a blast to drive, power all over the place.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Ill update when I get some heads.
Again, incorrect/irrelevant. The runners inside the plenum create velocity and flow to the cylinder head. The throttle body opening is simply an air leak and its only job is to keep air in the plenum for the runners to consume. I honestly steer everyone to the 92mm TB myself. Heck I run a 90mm TB on my 102mm.
You guys are supposed to be the knowlegable ones on this forum?!?!?!? I see a bunch of smart people that either are looking at bad data and believing it or simply dont have enough experience with the part being talked about. Any moron can get three pulls for $50 and get the crappiest data ever. By a dyno operator that has no clue or doesnt care about getting good data. They care about taking your money and then getting you out the door quickly. The FAST picked up my vehicle 21rwhp with my stock LQ9 (190s/200s @ .050.460/.470 lift) stock exhuast manifolds and all.
