Sound right?
Old Aug 20, 2010 | 12:05 PM
ParkerSS's Avatar
Default Sound right?
Ok a few weeks ago I had some work done to my SS and had it full dyno tuned by Vengeance and I made 347hp WITH TOPPED OUT injectors(still had stock). Knowing how bad and dangerous that would be to run i had a new set put in while i was there but didn't make another pull. Just wondering if my numbers are right or if I should be making more and if having the bigger injectors now will make a difference the next time i make a pull. Car and mods are as follows:
2000 SLP SS 74k miles A4
SLP Lid w/ K&N Filter
Hooker LTs w/ ORY
SLP LM1
FAST 92mm intake and TB
All free mods
Old Aug 20, 2010 | 01:58 PM
djfury05's Avatar
hopefully you had the injectors tuned for the car???
I made 349/367 headers tune only...
your not going to be able to utilize all that extra air without a bigger cam/heads.. that's why your seeing minimal gains.. you might have made gains under the curve tho
Old Aug 20, 2010 | 02:01 PM
ParkerSS's Avatar
Yeh I had them tuned right when they installed them. That's really what I want to do next is heads and cam i already have a set of 243's just trying to build my money up to get the cam and all the rest.
Old Aug 20, 2010 | 02:04 PM
Ultraz765's Avatar
I've heard the stock injectors were good to 400+ hp. I don't understand what you mean when you said "Topped out" Why would the injectors be maxed out?
I'm no tuner or mechanic, just tryin to learn
Old Aug 20, 2010 | 02:08 PM
ParkerSS's Avatar
They had to tune them to 100% for me to get even enough fuel to make power. my a/f ratio was horrible i was running so lean that it's probably a miracle i didnt blow the motor which i would have on the drive home if i hadnt went ahead and had them put in the bigger injectors
Old Aug 20, 2010 | 02:33 PM
Ultraz765's Avatar
I just never heard of the injectors doing that until h/c. but then again I've been out of the camaro loop for several years.
Good Lookin SS
Old Aug 20, 2010 | 02:35 PM
ParkerSS's Avatar
Thanks! And yeah I dont know what was up with it too much but they were the stock ones and had 74k miles on them which may have made a difference lol!
Old Aug 20, 2010 | 02:40 PM
incbed's Avatar
When I was at Vengeance last thursday getting my computer flashed he actually spoke about your injectors maxing out. That the 2000 f-bodies came with 26lb injectors.
Also your dyno session was brought up because I have a 2000 Z28 M6 and had the GM white injectors on my list of mods for my computer flash.
thunderstruck507's Avatar
I'm not sure why you were maxing injectors without a cam setup...
How is your fuel pump?
Old Aug 20, 2010 | 02:45 PM
ParkerSS's Avatar
Haha well nice to see I'm remembered I guess! Ron's a really cool guy though.
Fuel pump is stock. during all the work and after noticing my sh*tty injectors they checked the rest out and said it should be fine for now and I trust Ron and his crew so...
Old Aug 20, 2010 | 02:50 PM
djfury05's Avatar
yea its still just mind boggling you needed bigger injectors just for headers/intake.. have you got a new fuel filter lately? whats the pressure at the rails?
Old Aug 20, 2010 | 02:58 PM
ParkerSS's Avatar
Yeh I installed a new filter just before going up there actually. Like I said no problems now but as far as I know (bought the car from a guy who knew NOTHING about cars lol) the car IS NOT cammed. As far as the pressure I have no idea I have a brand new set of FAST rails w/ pressure gauge that I am waiting to install when I do my head/cam install.
Old Aug 20, 2010 | 03:22 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
I would check your fuel pressure if possible. I think its kind of odd that your injectors were maxed out at this power level. On my last car I was able to use the stock 26lb injectors for a heads cam setup that made some decent power. We are at a much higher altitude which would have a lot to do with it, but I still wouldn't think your stockers would have been maxed out. It is possible they were just bad though.
Old Aug 20, 2010 | 03:26 PM
ParkerSS's Avatar
Will do. Ever since my A/F guage reads perfect though, never really lean unless decelerating or at an idle. It does surge a little when I first start it up though but it goes away after warmed up. I have deleted my EGR and AIR systems btw also no cats
Old Aug 21, 2010 | 03:17 PM
RJB01camaross's Avatar
Your numbers look good!
By Brett Foote | 2026-06-04 05:00:17
