Megadeath Cam Only
Old Sep 2, 2010 | 10:33 AM
onesicss's Avatar
BTW this was my FIRST Ls or V8 for that matter that i have built, i came from all motor stripped to the bone hondas! hahaha. its like starting ALLLLLL over from scratch on what works and what doesnt. I do miss being able to take apart the whole car with a 10mm tho haha
Old Sep 2, 2010 | 10:38 AM
Philip@HPE's Avatar
Originally Posted by onesicss
And Thanks for all your time on the phone yesterday philip you were a great help, its really cool to be able to talk to all you shop owners and workers and not feel as if were bothering you when were not sure what direction to turn. Prop to all you guys!
No problem. I'm here to help you guys.
Old Sep 2, 2010 | 12:51 PM
rjparth's Avatar
Man, those numbers sound way high for cam only. I just did 420rwhp and 396 rwtq with the mods below.
Old Sep 2, 2010 | 01:13 PM
sscamaroburn02's Avatar
they are just numbers. track will tell the tale
Old Sep 2, 2010 | 01:23 PM
427LS7HCI's Avatar
I had a buddy who swapped his MTI X1 cam and put in a Megadeath cam in his C6 and he made more power, but his track times were slower. Torque in the low/mid range was substanially impacted negatively and he had stock 3.42 gearing. He pulled the megadeath out and put in a Pat G spec'd custom cam and made just as much power and ran faster track times.
Old Sep 2, 2010 | 01:50 PM
01SS99red's Avatar
Its not all about max power but power under the curve a nice power and tq. curve is what you want to look for not just max power. Like some just said track times will tell. post um up
Old Sep 2, 2010 | 02:05 PM
427LS7HCI's Avatar
The OP is going to be disappointed when he goes to the track.
I wouldn't run that cam with TFS 215s/FAST 102, it leaves too much power in the midrange on the table. Megadeath cam and 215s is a mis-matched combination.
I'd go with TFS 215s/FAST 102 w/90mm TB, but preferably a FAST 90 or 92 if you can get your hands on one, and something like a 234-236/238-240 112LSA cam.
Old Sep 2, 2010 | 02:35 PM
Jonnie Bravo's Avatar
Exactly, if I was running that cam my next mod for sure would be a set of 3:91's to really benefit from such a high reving, upper end cam.
Old Sep 2, 2010 | 02:47 PM
onesicss's Avatar
Yea I dont think I'll be disappointed at all, well.... Cause I'm not, it's a blast to drive and track times don't really make much difference to me since it's not a track car, don't care about low end cause the car never sees low end anyway, mid range is fine and pulls good and really good up top. Combined with heads and intake (still to be decided) will help everything alot and not to mention future plans for 402 or 408 with 11 or 12:1.. Agreed gears... Yeaaaa haha bout that, could realllly use 3:73 or 3:90s.
Old Sep 2, 2010 | 02:48 PM
onesicss's Avatar
Jonnie bravo, muffler first... It's wayyyy too loud, then gears it is
Old Sep 2, 2010 | 03:39 PM
427LS7HCI's Avatar
3.90s? more like 4.30s or 4.56s
Old Sep 2, 2010 | 03:47 PM
  #32
427LS7HCI's Avatar
AFR 215s/FAST 92 would be a great combination.
Old Sep 2, 2010 | 03:59 PM
  #33
onesicss's Avatar
Yea, I think ur probly right... Kinda what I was planning on cause I can find them used around town pretty easy.... Don't wanna spend 1000 bucks on a manifold
Old Sep 2, 2010 | 06:01 PM
  #34
01SS99red's Avatar
WEll for a street car point of view roll racing and such you might be alright with 4.10 s . but for drag car setup def. would need 4.56 and 28 in. tall tire. Either way enjoy the new power and update with track time in the future.
Old Sep 2, 2010 | 08:38 PM
  #35
onesicss's Avatar
I will, as soon as I make it out there. Probly round end of season.
Old Sep 3, 2010 | 08:11 AM
  #36
Philip@HPE's Avatar
Does your buddy have documentation of this because I would be interested in seeing it. Was the car run on the same dyno's and run with the exact same track conditions with each cam?
Old Sep 3, 2010 | 11:56 AM
  #37
onesicss's Avatar
Thanks Philip, kinda tired of this " theres only one best cam for everyone and only low end matters and that pat g is the know all be all and that the people who build these packages an have proved the results don't know anything treatment" I'm sure pats great but i also know that so are all the other guys such as HPE that are as well otherwise it'd be a little hard to stay in buisness. Different strokes for different folks.
Old Sep 3, 2010 | 01:11 PM
  #38
427LS7HCI's Avatar
Yes he does. Furthermore, the Megadeath cam is not a cam for a stock geared car and the cam needs gear to appreciate its potential.
Secondly, the PTV clearance with that cam on stock heads and non-notched pistons is WAY to close for comfort on a street vehicle. A bump against the limiter or an overrev and the bottom end is outta there.
Lastly, I've never been a fan of the Megadeath cam. If I were going with a cam that size, I'd choose Thunder Racing's T-rex cam and get notched pistons.
Old Sep 3, 2010 | 04:34 PM
  #39
onesicss's Avatar
As stated earlier.... Yes it does need gears agreed. BUT too big for street? Too big for who ... You? Because I don't see what the difference is between the car being drivin on the street or being drivin on a track makes on the PTV clearance. Usually why u upgrade to stiffer springs double roller ect. And no a bump off the limited won't make the bottom end "outta there." 2. No one asked if u were a fan of the megadeath nor cares. I didn't see you in the shop helping install it so idc what cam YOU like but I know if u posted numbers ect. And were happy with it I would bash or tell you what you shoulda have done I'd rather let u enjoy what u got.... Thanks for the opinion anyway
Ps. No one dare to be different, just use the same cam, heads, ect as your neighbor then we'll all run the same times and numbers and then we would never have to think about set ups and it would be great....
Old Sep 3, 2010 | 09:03 PM
  #40
BaddBird's Avatar
Man, your an ***. You think the T-rex is going to be any better on stock gears? I would probably bet that both of those cams have similar PTV clearance.T-rex might even be closer with it's tighter lsa. If the Op is happy with it who gives a **** if you are not a fan. Nice numbers OP.
