EFI 4 Barrel/Victor jr vs 95mm/FAST 92mm
Thinking about swapping out my 95/92mm FAST setup for a EFI 4 barrel and high rise intake. Does anyone have and comparisons or have any experiance with the following? Will I lose or gain hp, do I need any special devices to run a EFI 4 barrel?
You can run it off your stock ecu. We have had very good gains at the track with a vic jr and 4150 tb. The smallest motor we have ran one on is a ls2 spinning to 7200 rpms. The proper setup with be a large stalled auto. You also need a cam designed for a single plane intake for it to give you the proper gains.
I personally see LS6 intake perform better than victor jr with elbow and 90mm TB
But also I have seen victor jr with 4-barrel perform better than fast 92mm on 383cid with custom cam to play the game with that intake RPM up to 7000 and that GTO made 530 rwhp via A4 !!! ..
Also try to get ported one !
