Dynojet to Dynomite Dyno Comparison on a 2011 CTS-V Coupe:
Bone stock, Vette Doctors Dynomite Dyno on 09-20-2010:
525 RWHP & 519 RWTQ
After the following mods, (9.5” lower pulley, CAI, 160˚, & Vette Doctors tune) Vette Doctors Dynomite dyno on 09-20-2010:
525 (stock) RWHP to 604.3 (modified) RWHP = 15.1% RWHP increase
519 (stock) RWTQ to 619.2 (modified) RWTQ = 19.3% RWTQ increase
The same car with the same modifications, (no other changes) on Mustang Magic’s Dynojet dyno on 10-04-2010:
556.2 RWHP
554.8 RWTQ
The Dynomite indicated 8.7% (.087) more RWHP than the Dynojet
The Dynomite indicated 11.6% (.116) more RWTQ than the Dynojet
Or:
The Dynojet indicated 13.1% (.131) less RWHP than the Dynomite
The Dynojet indicated 16.2% (.162) less RWTQ than the Dynomite
525 RWHP & 519 RWTQ
556.2 RWHP
554.8 RWTQ
Or:
Last edited by Gary Wells; 10-08-2010 at 02:31 PM. Reason: Mustang dyno reference should have been Dynomite dyno
Thanks for the comparison ...
I really think 604rwhp is high with your mods the dynojet numbers seems right for the mods though...
we tuned CTSV 09 M6 with CAI / Upper & lower pullies / 1.7/8 Headers ORX and mild cam 630rwhp 645rwtq
Is the car M6 or A6??
Congrats on the car and numbers..
FWIW, I believe that is a M6, or manual
If you guys did a bone stock, no mods, baseline run I would sure like to have the info for my charts.
I would need the following:
RWHP--RWTQ---Trans----Locale-----Owner------------Date-----------Dyno
I would also need the correction factor , if any, applied.
venom ws7:
I will try to get the dyno graph
470rwhp 445rwtq SAE Smoothing 5 on dynojet Manual 09 CTSV
90f weather...
Cad bone stock RWHP & RWTQ (Manl) (dynojet only):
466------464------manl-----Kali------Luna------------05-??-09--------Dynojet
470------445------manl-----????-----venom ws7-----??-??-??---------Dynojet
494------483------manl-----Txs------Silver –V--------01-16-09-------Dynojet
500------481------manl-----Ala------roarkb-----------03-06-10-------Dynojet
502------490------manl-----Txs------TrevorD---------12-25-09-------Dynojet
Manual bone stock RWHP & RWTQ ( dynojet only) 5 samples:
RWHP Average (5 samples) = 2432/5= 486.40 RWHP
RWTQ Average (5 samples) = 2363/5= 472.60 RWTQ
Verified: 10-08-2010
Got a location such as state & a date?
466------464------manl-----Kali-------Luna-------------05-??-09-------Dynojet
470------465------manl-----Arab-----venom ws7------04-20-10-------Dynojet
494------483------manl-----Txs-------Silver –V--------01-16-09-------Dynojet
500------481------manl-----Ala-------roarkb-----------03-06-10-------Dynojet
502------490------manl-----Txs-------TrevorD---------12-25-09-------Dynojet
RWTQ Average (5 samples) = 2383/5= 476.60 RWTQ
Thanks, Venom
Thanks, Venom
HTH
All of my tuning was on a Mustang (which they are good for) but I always wondered what it would do on a Dynojet. I have "heard" 5% is a conservative conversion but also that the more power the car puts down the larger the difference.
Very interesting information in this thread by the way
If you look at the hot-linked thread / post below, you get a pretty good picture of where particular brands and / or types of dynos indicate.
https://ls1tech.com/forums/dynamomet...l#post13977203
LS1Tech Sponsor
I've seen several Vs dyno'd with similar mods and the 550ish numbers are right in line with what everyone else sees.
What would have been the best comparison, would have been to baseline the car on both dynos as well.
That way, you can calculate the % of power increase, which, no matter what the numbers are, should be the same.
Sorry,
The dyno results you posted really doesn't do anything for anyone. In order to show the differences in dyno outputs, the pulls musth occur within mins of each other. The condiditon has to be the same.
You are certainly entitled to your own opinion, but I believe you to be somewhat incorrect. I believe that all of the examples below are SAE corrected, other than one which is STD corrected, and as a general rule, the difference between SAE and STD can be calculated to a certain extent. And they really are within minutes of each other. Just multiply 60 mins by 24 to get the amount of mins per day and then multiply by the amount of days, weeks, months, and / or years. That way they will all be in minutes. And as far as not doing any good for anyone, you are the 1st one with negative comments. HTH.
Here's the complete grouping of 3 sets of differences between different brands of dynos.
Dynojet to Dynomite comparison on aj660’s 2011 CTS-V coupe:
http://www.cadillacforums.com/forums...d-up-my-v.html
modded & tuned: (9.5” lower pulley, CAI, 160˚, & Vette Doctors tune) Vette Doctors Dynomite dyno on 09-20-2010:
Dynomite (09-20-2010): 604.3 RWHP & 619.2 RWTQ
Dynojet: (10-04-2010): 556.2 RWHP & 554.8 RWTQ
Or:
Dynojet to Dynapack comparison on Jedhead’s 2006 Cad STS-V
http://www.motorgen.com/forum/showthread.php?t=21287
Mild tune, Church Automotive Testing’s Dynapack Dyno on 06-30-2010:
Dynapack: (06-30-2010): 443 FWHP & 430 FWTQ, CF SAE
Dynojet: (unknown date): 390 RWHP & 382 RWTQ
The Dynapack indicated 13.6% (.136) more FWHP than the Dynojet
The Dynapack indicated 12.6% (.126) more FWTQ than the Dynojet
Or:
The Dynojet indicated 12.0% (.120) less RWHP than the Dynapack
The Dynojet indicated 11.1% (.111) less RWTQ than the Dynapack
Dynojet to Dynapack comparison on Gary Wells’s 2009 Cad CTS-V
http://www.cadillacforums.com/forums...ew-dyno-s.html
Factory stock, Church Automotive Testing’s Dynapack Dyno on 10-11-2010:
Dynapack (10-11-2010) 510 FWHP & 531 FWTQ, CF SAE
Dynojet: (10-13-2010): 456 RWHP & 451 RWTQ, CF SAE
The Dynapack indicated 11.9% (.119) more FWHP than the Dynojet
The Dynapack indicated 17.7% (.177) more FWTQ than the Dynojet
Or:
The Dynojet indicated 10.6% (.106) less RWHP than the Dynapack
The Dynojet indicated 15.0% (.150) less RWTQ than the Dynapack
Regardless of atmospheric conditions, these readings should not vary that much between brands and / or types of dynos.
HTH
Or:
Or:
Or:
HTH
