Dyno comparo - PP S2 heads only swap
In summary the PP S2 style heads were worth 15 rwtq from 3000 to 5000 rpm and 1rwhp/10rwtq on the old peak numbers right? It would be nice to see the graph if possible. Older MTI S1's touched up by Hans flowed about the same on the flow bench? Any numbers to share?
Was the car dyno'd on a Mustang dyno? If so the numbers seem very good otherwise I agree with Vince.
Whould be nice to know what both sets of heads flow with & with out the LS6 intake in place. This doesn't strike me as much of gain for a ported Stage 2 set of heads over a touched up MTI Stage 1's with additional work. However as long as the customer is happy that's all that matters.
Edited: Should have said S2 in orginal post.
Originally Posted by Got Me SOM
you guys are so consumed with peak hp numbers, he said he picked up 15 ft lbs of torque from 3 grand to 5 grand. What more do you expect? He didn't change cams..
I'll take more torque and area under the curve over hp anyday.
Mitch, sounds like you did good on the swap as a whole! Congrats!
Matt
Shorty Director
Originally Posted by turbo'd stang
Good to know it dynos great, but what does it run at the track....where it counts?
I think what people are saying is that the milling of the head could be responsible for the increase in tq. I know that 1 comp point is worth about a 3% increase in power. If he got 1/2 a comp point it should be worth 18 lbs tq. Basically, milling your old heads would have done the job. Good luck but I think you got taken. I made more power running stock 241 heads. I really wonder how great these after market heads are.
Shorty Director
This is another example of a cam only setup making good #'s..
"2000 SS, t56, MNB, custom 220/220 cam, ZO6 intake, Jet Hot headers, Hooker ORY, QA1 12 way shocks, ASP pulley, 12 bolt w/4.11. Dyno 394 RWHP 376 RWTQ SAE w/ tuning through my 12 bolt. New time 12.01 at 117.7. "
By the way.. My Mustang Dyno #'s on my last setup was 397.8rwhp/374.1rwtq with a 3600lb load... The bad news is I did not get the dyno sheet until after the spring broke and the valve dropped. My car broke less than a hour off the dyno. When I looked at the dyno sheet I noticed my car peaked 350rpm earlier. If I would have seen the sheet b4 racing that bike I would have put two and two together. Good Luck Mitch. I am sure your track times will be good. Ignore me. I am just jealous you have a operational car.
there are too many variables dont read too much into dyno numbers unless they come out like 250rwhp then worry. I have PP STG2 LS6 heads/tsp 231/237 cam and i havent had it dynoed dont care to all i know is in the racing i do which usually is highway rolls on the way home from work i have a blast!!!!!
Some people on this board will never be happy with any thing that has to do with the word "Patriot". Even though Patriot is driving the prices of the people whom they use down, thus giving them a better deal. If you don't like them, good for you. Quit raining on other peoples parade. Just be happy that there is some competition out there in the head market, thus helping you in some way. If he even stayed the same in HP/TQ, he still gains in the pocket book. I'm sure the MTI S1's were far more expensive than the Patriots were, and he even got a little better TQ.
Raining on what parade? Read my earlier post. Milling the heads could have been the sole reason for the 10 lbs of tq. In my opinion you just gave someone $1300 bucks when you could have milled your own heads.
For the record, I am not a PP hater. TEA has dropped the ball several times. A friend of mine dump his ZO6 heads for some 5.3 ST2 TEA heads that were milled for more compression and only gained 7 hp above 5,500 rpms. He lost 10-12 below 5,500.
Finally, I know its hard for some of you to accept that you made a bad purchase or you got a bad set of heads. If I were you, I would call PP and let them know. I hear they are a good bunch of guys and maybe they will check your heads out. Just my opinion. Sorry if I hurt anyones feelings.
#32
Again, I could have spent $600 to have my old heads reworked or paid $350 difference in price between buying new PP heads and selling my old ones.
#34
Well that isn't my intention. I just think he needs to call PP and talk to them. I think they would agree that something isn't right.
#35
#36
#37
How do we know what was done to the mti stg 1 heads by the other guy(Hans) ? THese heads could have had a lot changed to improve them.
BOttom line, He saved money going from good heads that needed to be reworked to new heads . Dyno dont mean **** to me either. I dyno lower than most and have low end tq with my stg 1 heads done by an old school head porter that only got them to flow 257cfm int and 223 exh. Just bowl work and short turn smoothing but I have more low end with mac headers than JSears had with GTP stg 2 5.3 heads with 11.3 /1 comp. and FLP long tubes and True duals and running the TR230 cam. He dynoed 440+ rwhp but below 4000 I was 20 ftlbs tq above him. At the track he beat me by 1 tenth with him on 26x10 et drags and me on my little 16 inch Nittos.
My car was built for tq and it works great for my set up because it is still fully loaded. Mitch does seem down on power over some others but the fact that he picked up 15 rwtq over the other heads is gonna shine at the track.
I think you did great going with the new heads
#38
I didn't post this to be a cheerleader or a nay-sayer.
Too much energy for little to no return. Some folks get their "jollies" blowing holes in things. To each his own.
I posted to follow up on a promise I made when I first made the decision to go this route.
Most of the negative comments seem to infer extremes, glossing over the fact that I had heads that were worked, but needed attention for my application. Glossing over the fact that time and money were saved going this route. Glossing over the fact that yanking the heads was gonna happen either way. Glossing over the fact that I did see some gains.
Would I have liked to have seen more? Well, hell yes! Am I disappointed I didn't No.
I also am old enough to realize their are gonna be haters out there. I'm not asking for anyone to agree, condone, audit, evaluate, speculate or ********** my results.
I merely posted data. I'm not gonna defend what I have, but I'm also not gonna let someone go off on a tangent misinterpretting my words. That's childish and self-serving tripe. There are other websites for that kind of behavior.
