427 & EPS cam
#41
My 414 with Patriot Stage 2 heads, EPS cam 239/259 .624/.624 112lsa
made 526 RWHP and 485RWTQ thru a 10 bolt with 4:10's and a YANK PT4000
and a stock fuel pump. (not for long)
I'm guessing you will be close to 550RWHP
#52
Are you sure you're going to be at 11.7 CR with a -8cc piston and a 58cc chamber? I'm thinking probably going to be higher.... I would be very careful at that level. You don't have to run near race-gas compression to get good power. The gain reward/risk i think is getting a little too high.
