Si5 Cam Only Numbers
Old Nov 20, 2010 | 05:05 PM
1979rs/z28's Avatar
Default Si5 Cam Only Numbers
After a little misfortune with a broken valvespring that wiped out my old 226/226 cam I stepped it up some and went with a Si5 231/237.
Anyhow here are the mods to the car it made 401/371 with the old cam and spec 3 clutch. Everything was the same then minus dual springs, ls7 clutch and the new cam that was added. Car is a M6/3.42 Gears
Mods are:
Unported Fast 90/NW 90 MM TB
SI5 231/237 .589 .595 112+4
Patriot Gold Springs
7.400 Pushrods
SLP UDP
Pacesetter Lt's w/ORY and Dynomouth Catback
LS7 Clutch/LS2 Flywheel
SLP Lid/Stock maf/Bellow
Dyno'd on TT2's with 315 Nitto 555's
New numbers are 417/383 I'll post up the dyno graph in a few minutes.
Old Nov 20, 2010 | 08:12 PM
01SS99red's Avatar
Good numbers. Congrats
Old Nov 21, 2010 | 10:36 PM
1979rs/z28's Avatar
Thanks man! Heres the dynograph
Old Nov 22, 2010 | 11:40 AM
djfury05's Avatar
good numbers man!
Old Nov 22, 2010 | 11:55 AM
LS1 SPEED's Avatar
GOOD NUMBERS
keep in mind you added weight with the Ls7 clutch/flywheel as well and the gains are still nice
Old Nov 22, 2010 | 12:34 PM
ibanez7's Avatar
running the same cam... its a great cam, track and street, with great sound!!!
speed did an awesome job on that grind!!!
Old Nov 22, 2010 | 01:40 PM
SLOW GTO's Avatar
Default ..
nice numbers.
Old Nov 22, 2010 | 02:43 PM
LS1CALIBOY's Avatar
Sweet numbers bro!!
Old Nov 22, 2010 | 02:57 PM
RJB01camaross's Avatar
Awesome numbers!!
Old Nov 22, 2010 | 07:04 PM
TXZ28LS1's Avatar
nice!! I have always liked that 231/237 cam.
Old Nov 23, 2010 | 09:11 AM
SOMbitch's Avatar
AWESOME Jamie!!!!
Old Nov 23, 2010 | 01:16 PM
DTB_LS1's Avatar
Solid numbers!!! My SI5 has served me well.
Old Nov 24, 2010 | 09:37 PM
1979rs/z28's Avatar
Thanks everyone it seems pretty darn strong IMO.
I'll try to get a easy pass in on it soon can't do too much on the 10 bolt though.
Old Nov 25, 2010 | 01:11 PM
WSsick's Avatar
Good gains for just a cam swap on stock heads.
