SAE and regular dyno numbers
Old Feb 8, 2004 | 02:33 AM
taqwache's Avatar
Default SAE and regular dyno numbers
whats the differents?
Old Feb 8, 2004 | 03:35 AM
mikemodano9c's Avatar
sae is variable corrected (weather, altitude???)
std is what your car was making on the dyno
sae is used so we can compare numbers taking in account all those variable factors...
Old Feb 8, 2004 | 12:12 PM
verbs's Avatar
I'm not sure what you mean by difference, but there are usually 3 different sets of dyno #'s you'll see.
Uncorrected, corrected SAE and corrected STD.
All corrected dyno #'s factor in temperature, barometric pressure, etc.., and tell you what you would dyno at a given temperature.
STD and SAE are the two different correction methods that are used, but the SAE is the correction method most widely accepted, and is what we here at LS1tech use to compare and contrast horsepower #'s. (***NOTE...every dyno is a bit different, and dyno's should in theory be used only for tuning purposes, but we all just can't help ourselves when it comes to bench racing )
SAE stands for Society of Automotive Engineers, and STD stands for standard. STD corrrected hp #'s are a bit higher than SAE horsepower #'s due to different correction factors.
Uncorrected #'s show what power your car makes in the conditions you dyno in. I could dyno the same car when it's 100 degrees and humid outside and make 350rwhp, but when it's 30 degrees outside, dry, with a great barometer, I could dyno say 380rwhp. That being said uncorrected#'s wouldn't allow you to accurately gauged changes in your dyno#'s since not only your mods, but the weather changes would have an impact on your #'s.
Old Feb 8, 2004 | 12:31 PM
Cokeroker's Avatar
i am ignorant and not 100 percent sure, but I thought that SAE stood for Standard Atmosphere Enviroment.... meaning the SAE corrects the numbers to what your car would run at a standard atmosphere... ie pressure 29.92, 70 deg, certain humidity etc etc...
the weather guy
Old Feb 8, 2004 | 07:45 PM
verbs's Avatar
the weather guy
You are close on the weather conditions idea, but the SAE we're talking about here is a correction factor devised by the Society of Automotive Engineers.
SAE Standard J1349, applies the following weather station data- atmospheric pressure 29.23, air temperature 77 degrees Fahrenheit and humidity 0 percent to all tests.
Old Feb 8, 2004 | 08:01 PM
taqwache's Avatar
cool. i knew what SAE stood for but did not exactly know what it meant for dyno numbers. i just checked my dyno sheet and it does say SAE HP and TORQUE. so i guess it is correct.
Old Feb 9, 2004 | 05:12 AM
Cokeroker's Avatar
right on.... 29.23 is pretty low of an altimeter setting... not actually ever that low unless under hurricane conditions..... is this number 29.23 correct? 29.92 is known as standard atmosphere... not trying to argue at all... am just curious
