T-rex Cammed 02 Trans Am Dyno Sheet!
Old 03-08-2011, 09:20 AM
LSX Mechanic
Damian's Avatar
I like your bed sheets.
Old 03-08-2011, 03:30 PM
Johnnystock's Avatar
Originally Posted by 19BLACKBIRD99
the rev limiter is set to 6200 because my injectors and fuel pump were maxed out if we went higher, so I bought 42 lbs injectors and racetronix fuel pump with the wiring harness for more power to the pump, so Im interested to see what it will make and what it will rev too.
Im curious as well to see!! Trex can be revved way higher..
So not too much surge n buck on the highway in 6th under 2K rpm?
Old 03-09-2011, 08:38 AM
chon79's Avatar
I had it quite a bit on 3.90s, but alot of it went away with 4.11s and some re-tuning.
I talked to Thunder Racing about it, and the recommended at least a 4.33 gear for the cam.
Aside from the surge, the cam is extremely driveable.
Old 03-09-2011, 01:16 PM
2slow2flurry-ous's Avatar
Creepy lol.
Old 03-09-2011, 01:19 PM
Thanks for the input..anyway I got an old small 22x TR cam and it does surge in parking lot but very driveable n 6th gear at 1000rpm is good!
Old 03-10-2011, 12:38 PM
Intercooler2's Avatar
Great numbers! About what I would expect stock heads 460ish.
Old 03-10-2011, 01:38 PM
BayAreaSS's Avatar
He has stage 3 ls6 heads
Old 03-10-2011, 03:12 PM
Oh. That's still pretty good. I'm always under the impression the M6 cars should dyno a little more so its pretty good.
Old 03-10-2011, 05:23 PM
99peweterls1's Avatar
This is making me want this cam. Very nice numbers. I would Like to see a trap speed and also a little roll action. What is the life expectancy of springs with this cam?
Quick Reply: T-rex Cammed 02 Trans Am Dyno Sheet!
