need an educated guess?????
Old Mar 9, 2011 | 12:31 PM
newschool72's Avatar
Default need an educated guess?????
ok this is what im building. LS3 w comp 269LSR (219-235 at .050, 607-621 on 113 ) vic jr intake w fast EZ efi, 1 7/8 longtubes. trans is a 2004r w lockup 2200 stall, 8.5 10 bolt w 342 gears. its going in a 72 camaro. so am i far off base thinking around 400 rwhp . shoot it to me straight guys. thanks
Old Mar 9, 2011 | 01:46 PM
zz4camaro1980's Avatar
400 will be EASY
Co-workers LS3 C6 with intake/exhaust just put down 413/402 on a mustang dyno. With a cam 400 wont be a problem.
Old Mar 9, 2011 | 02:36 PM
my only concern is the vette has a very efficient drive line and im running an overdrive trans.
Old Mar 9, 2011 | 04:22 PM
*02WS6TURK*'s Avatar
Go with a EPS cam.
Old Mar 9, 2011 | 06:26 PM
all respect dude, but the comp is in the engine. not looking for recommendations on cam choice, just thoughts on what i have. im sure eps profiles great shafts. anybody run that comp269 lsr ?
Old Mar 9, 2011 | 09:19 PM
ChucksZ06's Avatar
If your comp is at least 11:1 and you have the valve springs to run 7500 rpm to get to that intakes sweet spot you should make 400 no problem. I am assuming good exhaust, tune, and well put together engine. With the aftermarket efi and that intake you can go a lot larger on the cam in the future and get it to idle great. Way easier to tune than the factory pcm's.
Old Mar 10, 2011 | 06:49 AM
it is a bone stock long block except of course for the cam. compression is 10.7 on the LS3 . i am running the recommended dual springs for the cam. comps claim on power band is 1800 to 6700.
Old Mar 12, 2011 | 08:40 AM
ok guys, ill take an uneducated guess.....i know,i know its a little cam w a carb style intake and a tb , just throw a number at me.
Old Mar 13, 2011 | 06:19 PM
GoFastKid's Avatar
