Tick Performance Polluter H/C LS1 Camaro
The car has quite a bit of surging and bucking which the tuner said it would do. He said they had trouble tuning with the FIC injectors I had. I don't lug around 1500 rpms anyway but it is a PITA when starting off from a stop. I hope ditching my 3.23 gears for 4.11's will help that though. I also went with solid motor mounts and it makes me not want to even drive the car.
I only banged the gears twice so far when I was on the highway and holy hell its a beast. Going from bolt on to this is unbelievable. The cam pulls super hard and doesn't quit. I'm going to ditch the SLP Loudmouth for something quite so I can actually go above 3k RPMs on the street.
Thanks to the folks at Tick for helping me out and answering all my questions. With a lid and 92/92 460+ easy out of this setup.
Nice looking curve on the sheet, you get that intake and the gear issue taken care of and the car should be strong.
Post up your results when you switch, I'm curious to see how bad that is hurting I use the run the same setup but did too many mods at once to see how much it actually helped.
Well you would be wrong. I have seen a MS3 cam only car go from 385 rwhp to 415 rwhp with the kit that has two k&n filters on it to an slp air lid set up. Same day, never pulled off the dyno. Never would have believed it until we saw it.
I have seen 10 rwhp with pre t/b intake changes... but never any more then that. But that thing, I can surly see it making at least 10, possibly more.
