Dynoed setup power seems low/Update tune posted
Old Mar 23, 2011 | 08:46 PM
Quick99TransAm's Avatar
Default Dynoed setup power seems low/Update tune posted
Engine Is 6.0 flat top pistons L92 heads with light clean up and milled 25 thousandths with stock ls3 head gaskets ,Ls3 intake ,long tubes and GM hot cam.And before we start bashing the hot cam I did my research and I know there are a lot of other cams but the hot cam fits my needs.
Should this combo be making more or does the power look good
Attached Thumbnails Dynoed setup power seems low/Update tune posted-scan0001.jpg
File Type: tun
Old Mar 23, 2011 | 09:59 PM
bozzhawg's Avatar
Auto:
435rwhp
405rwtq
Manual:
450rwhp
425rwtq
Bozz
Old Mar 28, 2011 | 10:29 PM
Johnnystock's Avatar
auto or manual? What car, rear end, exhaust setup, intake setup?MAF? I know boltons LS3 are usually between 380-400rwhp. It does seem knida low to me.
I will not start the hot cam bashing..
Old Mar 29, 2011 | 05:39 PM
Default Car
Car is an auto T/A with 323 gear custom cold air intake exhaust is long tubes 3inch y pipe over axle into slp loudmouth and dumped.Car is speed density so no maf
Old Mar 29, 2011 | 08:16 PM
gtotoocool1's Avatar
stock or aftermarket TQ?was it locked during the run?
IMO there's nothing wrong with the Hot Cam at all.
Old Mar 30, 2011 | 07:29 AM
Slowhawk's Avatar
LS1Tech Sponsor
The graph is wavy which tells me there is an issue.Could be electrical or tune. The curve looks low like the cold air might be restrictive at a stand still dyno.
Yes, the hot cam does suck bad in a LS3 but should still make 400rwhp.
Old Mar 30, 2011 | 05:08 PM
Default Converter
Was told converter was locked and it is stock.The cold air is 3.5 inch pipe into fender under battery with a large cone filter.
Old Mar 30, 2011 | 06:07 PM
Detoxx03's Avatar
Yeah that is very low imo
Old Apr 1, 2011 | 10:30 AM
redtan's Avatar
That's basically what a bolt on 364 should make. You have better heads/intake a bigger cam, so there's no reason why you shouldn't make more power.
I would also question the intake tube and filter, as unless there is a mechanical problem with the engine that seems to be the only sub-par part.
What sort of MAP and IATs are you seeing on the dyno?
Old Apr 1, 2011 | 10:36 AM
Default set-up
Iat's were show between 70-80 and the map readings showed that there is no restriction in airway.The engine has 611 miles it is completely fresh.Trying to get the tuner to send me the tune so I can post to see if people see any issues because this set up make almost the same power as my 6.0 with ported heads intake and full exhaust
Old Apr 1, 2011 | 11:04 AM
Slowhawk's Avatar
LS1Tech Sponsor
The inlet is a problem.Bends ect hurt airflow. Step it up to a 4" pipe.
Old Apr 1, 2011 | 06:18 PM
s346k's Avatar
Umm what valve springs?
Old Aug 22, 2011 | 11:23 AM
iraqi devil's Avatar
was there an update on this?
