Odd spike in dyno graff.
My build is a 408 with a 96mm dbb turbo. Around 4500 to 4800 rpm's we get a 50hp dip in power before it takes off like a scalded ape. We hit over 800 at wheel at 14ish #'s. My injectors are ID1680's and their duty cycle is 68%. The fuel map reads a steady 11.5 11.6 to 7k. We changed a dozen plug setups and my wires are new Taylors. My plug is an Autolite 103 gapped at 22. Any ideas?
car is a hunk of **** anyway. You should part it out and sell me some stuff dirt cheap.
Tyler
Were you dataloging ALL the timing advance/retard areas?
Engine -> Advance
AFR Advance
Base advance
Coolant Advance
Cranking advance
EGR Advance
IAT Advance
Idle Advance
Ignition timing advance
Smoothing advance
TQ Management advance
Engine -> Retard
Burst Knock Retard
Knock Learn Factor
Knock Retard
Startup Retard
It's worth looking at.
The times I have seen the cam drop power and come back up, it doesn't do it as sharply, it's a bit more smooth and over a longer rpm range, but that's in a NA motor. I can see the spool of the turbo affecting the recovery, but not the drop. I think it would still fall off a bit more smoothly then come back faster do to the turbo spooling, but that is a guess. What rpm is the turbo starting to build boost?
Here is a picture of my old 347 with a Trex/heads. The two graphs are obviously NA, one with an LS6 intake and the other is a Super Vic. But you can clearly see more of a mellow drop off in power. I'm not sure that the cam iss the issue.
im wondering if my pre turbo exhaust isnt restricting. then headers go into a t4/t6 flange and then into the t6 turbo
tire spin or clutch slip also not an option.
i have little huumps and bumps like that on my graphs, but if the car runs good at the track, has a steady afr, and the timing is smooth PRIOR to the dip, then there really isnt anything to worry about
Would def like to see a data log of it. It kinda looks like a converter unlocking, but that's out of the question obviously.
and do cams have a power limit?
I had a turbo Fbody I tuned one time, no matter what I could not make 700 rwhp out of it. It made 699.something numerous times. I tried letting it cool, running it hot, more timing, less timing, etc etc etc. Just wouldn't do it. Then the customer wants to know "you mean to tell me you couldn't crack 700 rwhp?" It was less than 1 hp away! LOL
