AES 390FI Dyno numbers
Old Jun 13, 2011 | 09:01 PM
GJL0180's Avatar
Default AES 390FI Dyno numbers
Has anyone dynoed a AES 390 FI longblock before they added FI? I have searched and have found nothing so far.
Old Jun 14, 2011 | 12:27 PM
Tirefire's Avatar
I'm in the process, I've got the block all together now and waiting for my rockers to get back from getting a trunia upgrade. I've got this going on the block: D-1 w/3.40 pulley, lonnies double pump fuel system and alky control hoping to get north of 700 rwhp!! I too have been trying to see some dyno results with an AES 390.
Old Jun 17, 2011 | 01:31 AM
Pwebbz28's Avatar
The 390 has been made to gain some piston strength in the crown area. It's going to make close to the same power as a 400 cube motor.
Old Jun 22, 2011 | 10:08 PM
madmax4499's Avatar
9.3 to 1, 390 my opinion would be approx 500-550hp or a little less than a higher compression N/A set-up. if you want one for N/A till you can finish up your turbo set-up just spray it with a 150 wet shot and still have tons of fun.
Old Jun 23, 2011 | 06:28 AM
Orange Juice's Avatar
1970 AMC Javelin. AES 390ci. MAST CNC LS3 heads,DragonSlayer-Ultra rods, Vic.Jr., wilson, N-W 102 T/B, 95lb. "FIC 1000cc. injectors", Lonnies Performance twin pumps/harness. Twin TC-70-65's flipped manifolds, A/W intercooler, TH-400, Griner 1+2 trans brake, PTC converter, 3.50 gear 29-18.5-15 tires. Alston Battle Cruizer 4-Link, Fab-9. Cage, tubs, PSI harness, 0411 ECM. EFI Live,
So this is the new take on a 390 Javelin.
Old Jun 23, 2011 | 10:17 PM
madmax4499's Avatar
i guess you could call it that. LOL, should be fun.
