346 LS1 w/auto N/A hp numbers
Just completed the LT1 to LS1 swap into my 97 Camaro. Put it on a Mustang Dyno and was very pleased with the results......525 rwhp 560 tq. through a th350 and a 12 bolt. It will get a shot of nitrous put back on it after a few passes at the track to make sure everything is good to go.
14-1 compression, ETP highly moddified stock heads, custom cam 745/754 on the lift, solid roller motor, aluminum rods, Jesel shaft mounted rockers, Vic Jr style intake, Accufab 4150 style TB, vacuum pump, tuned with a BS3 on a Mustang Dyno which normally shows lower numbers. What is the HP record as of right now?
So, you put stock pistons back on some aftermarket aluminum rods while still retaining 346ci? Most usually do a good clean up on the block and hone it for some pistons to 347ci. Why would go through all that and not do it?
Hey, its a dyno section....graph should be a requirement lol!
Very nice setup! I almost wanted to go with the Victor Jr, but didn't feel like hacking up the car....So I went with a Mamo Ported 102.
The new block makes sense! Thanks, I was scratching my head at that one....
