Track results: Is my H/C 346 LS1 really making 500whp?
420-440 as others have stated. No one is hitting 500 rwhp with an ls6 intake on the car and 1 3/4" headers on stock displacement.
Calculators are dumb...there is a lot more to trap speed than just peak horsepower. Gear ratios (tire size as well), average horsepower, torque curve, etc.
You have a very stout car though, 130 mph in the 1/4 is no joke.
that's funny because 99% of the time people are saying, "who cares what a dumbass dyno says, get your car to the track". I will get it on the dyno and it will most likely read 450+/-10rwhp... I was mistakingly following a bad calculator that has proved very accurate for me in the past. 130mph does seem abnormally fast, so I had to ask the question.
This one is good
here you can see both RWHP and Engine hp
based on ET time and ET trap
http://vexer.com/automotive-tools/1-...MPH-calculator
but et trap is more accurate unless you have 100% run
Baezi
Baezi
#33
haha alright... ask someone who just went through the work to drop 200-300 lbs off a car if that much weight isn't worth taking into account
. needless to say i'm pretty happy with the power the car making... whatever it might be. I was really just looking for an explanation as to why a calculator that I have found to be right on in the past is spitting out an unbelievable number... I guess there's just too many factors, but I do agree that the wallace racing one seems much closer to reality.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#35
"Input the Weight and 1/4 mile Trap speed of your vehicle. Our Calculator will generate its rear wheel horsepower".
The wallace one is much better I have come to find, so I will be using it from here on out.
I am definitely working on my 60' times... they are the only thing holding me back right now. I need about 0.150sec to get my 10 second slip... I just bought a set of ET Streets and some skinnies to try and get there in a few weeks.
#37
LSX Mechanic
OP, do you have a video of your pass? If so, post it. I'd like to hear your driving skills before making an assumption.
One key fact a lot of people tend to forget when arguing MPH is how fast you shift. I've jumped in peoples' car before that was going slower than it should, and picked up 4-5mph based on better driving/shifting alone. I'm also typically bigger than most of those people (235lbs) so I added weight at the same time.
I'm not saying this is the case with the OP's car, but it is something to think about. A car capable of 135+ traps can be brought down significantly lower with 4 slow shifts.
#38
I guess I should clarify... I am wondering because I have usually found online calculators such as this one, which use both weight and trap speed, to estimate horsepower. The reason these are generally very accurate is because "simple" physics can be used to estimate force when the accleration and mass is known.
http://www.race-cars.net/calculators/et_calculator.html
#39
My car dyno's 451 rwhp and traps 127mph in about 1000 da. weight is 3200lbs in a camaro.
I would think that with yours being about 300lbs lighter and maybe slightly more areodynamic 130mph would be expected with 450rwhp....ish
But also mine is a 4l60e car with a 3600 unlocked converter and you are 6 speed...
I think I did those online hp/1/4 calculators and they say my car should be 550 rwhp or something...
Either way your car runs killer strong and is deadly from a roll. to bad my dodge ram isn't that way
