Back to Back Dyno Test – PI 215’s & Ai CNC’d GM 5.3
#42
Was that with stock valve sizes? Nice post by the way. Man it would have been even better if you just happend to have a set of ai 241's to slap on as well. I know everyone says 241's are junk but I want to see real results. Obviously 243's are better but I got a set of 241's for 70 bucks with low miles and if it's like a ten horse difference only that isn't too dramatic to me. I've seen pretty good flow numbers from 241's but I swear it's like impossible to find 243/799 heads under 400 bucks. So 241 could potentially be a sweet budget build? Haha.
#43
So was I dumb to take apart a setup that was "OK"...maybe, but I have always been willing to take a risk. What "racer" isn't willing to go thru a little headache to gave power? Did I know I would...NO. But going with AI I felt confident that good things would happen. And now I have a "MORE" powerful, yet more driveable while still economical car. I just bought a 2012 VW GTI, its rated at 24/33mpg. With the AC on and cruising at 80mph on the freeway, I have been knocking down 27-28mpg...funny that my LS1 H/C/I SS is right there at 27mpg...And the LS1 will blow its doors off. So a no compromises daily driver type setup is what I was after, and while it might not be perfect, its really really close.
#44
Man, we really need more of these threads to show what a REAL H/C setup can do. Seems like everything on this forum just throws a big dick cam in a car with stock heads, stock intake, and a **** tune and wonders why they don't even break 400 at the wheels.
Props to the OP for actually trying to do it RIGHT and make some real power without losing fuel efficiency.
#45
Over camming a car seems like a big problem on this website. I went with Phil and got a set of his ported 243's and a matching cam for my 383. I can't wait to see the end results.
To the op, I take it your a pharmacist. My girlfriend is in her 3rd year of pharmacy school now, go big money!
#46
For the skeptics out there, these are real world results. These guy's have nothing to gain by getting on here and boasting about one product over another, it's a legitimate comparison and I'm glad those guy's got his setup figured out! The big name isn't alway's the best route to take!
#47
Jason
#49
The cam was a custom spec comp cam from Va Speed...it was clarified to me later that this was a custom grind Va Speed did for quite some time, until comp released it (recently) as an off the shelf grind. Either way, it was their suggestion based on the information I gave them (how I planned to use the car and my personal goals) for the heads/intake/gear/curb weight etc for my setup. To keep the comparo apples to apples we didnt' change the cam for the AI heads. Phil commented earlier I believe on this topic, but essentially, there really wouldnt' be any significant gains from changing the cam (probably at all)...especially not without giving up an unacceptable amount of drivability
#50
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#51
The cam is 231/239 LSR cam right off Comp's site. Those cams were out long before you got this stuff...
#52
With the exact same specs down to the LSA and the advance...exactly the same as the other 3 LSR cams that Comp released for street use in cathedral port engines?? Come on Brad, they mislead you on the cam. They chose a cam that has the newer LSL lobes but had specs close to a G5X2 because you wanted strong power, but decent economy and driveability. Yes its a nice cam, but they blew smoke straight up your ***!
Glad you guys like it either way. Perhaps Brad will run it on other dynos or be amenable to future changes.
-Phil
#54
While I understand that this may not meet people's expectation of what a "custom grind cam" is, it is notable that you'd have to indict more than one shop if this is the litmus used to determine whether or not something is a "custom" cam. The majority essentially sell the same cams ground by comp, and with Comp anything ordered with lobe #'s & centerlines is considered a "custom grind." They consider it a shelf cam if you buy the cam by part #, in this instance "54-459-11." We sell a bunch of ~230/234, 230/238, etc. grinds on 112-114lsa's... it should come as no surprise that comp has a common grind/shelf cam with those specs. In the end, the flow # games pale in comparison to the camshaft misinformation regurgitated on the forums, but this isn't something I'd be terribly hung up on. This isn't even in the same league as the guys misrepresenting the actual characteristics of cams (e.g. selling relatively aggressive cams as mild, etc.) since the former has no negative effects and the latter does. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Glad you guys like it either way. Perhaps Brad will run it on other dynos or be amenable to future changes.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
-Phil
-Phil
Car is a beast for no more than what is done to it tho... a real "top end" car with the 3.42's still in there. Drove it down today to take the wife out to eat. Pulled a steep incline today in 6th gear turning 1300rpm (accelerating with only 1/4 throttle). That is what makes this setup so special...it has guts down low and up top...the previous aftermarket casting setup was noticeably less gutsy down low...noticeably less power under the curve...if you can tell from SOTP, its major and it was.
The fact of the matter is, if you want hype and marketing...if you want your ear tickled...don't call Phil @ AI...If you want FACTS and HONEST #'s, you NEED to talk to Phil...AI is NO BS. In an economy like this, don't waste your money...I did and I'm still paying for it...Do it once, do it right, call AI!
#55
I've read this a few times, but same valve sizes?
Did you check how the fast lined up with both heads? I know this is not something that would be your problem is one was better fitting then another. And a miss linement should be part of a as "stock parts" out of the box, back to back test.
I see there both SAE corrected, but what was the correction %?
The PI head was dyno'd back when it was cooler winter/spring, and the AI head was dyno'd this summer fwiw.
#56
![Lightbulb](https://ls1tech.com/forums/images/icons/icon3.gif)
No, I run stock 2.00/1.55 diameter valves whenever possible vs. larger valves like the PI 215 & many other aftermarket heads use. It is a better setup all around.
The entire setup he bought initially included the FAST 102 ported specifically to work with his PI heads since the entire top-end came from the same vendor. It isn't worth porting the FAST manifolds for many setups, and to ensure it all fit together I simply had Brad swap to an unported/stock manifold lower since I have no idea how one ported for the PI heads will mate to ours.
Close, 1-1.5% either direction to compensate for ~15deg & .2 in-HG IIRC
#57
Considering the cam works well for what Brad wanted, I'd say he came out just fine. I don't know what he paid for that "custom" cam, but it couldn't have been much more, if any, than a true custom piece that AI will spec for someone buying their heads.
Something I'm curious with though is that what would AI spec to eek out alittle more across the board while using a less aggressive lobe? Phil seemed to indicate he could do better on less of a spring-killer lobe.
Jason
Jason
#58
Sorry to bring this thread back from the dead, but I would love for Phil @AI to answer Camro99SS's question in the previous post.
Brad,
How is the setup running a year later?
Brad,
