New stroker results
Old Dec 19, 2011 | 01:07 PM
FlamingTA's Avatar
Default New stroker results
I finally got some early results from my stroker build that has been going on for most of this year. Mods are:
06 GTO 6-speed stock gears
ERL stock sleeve 421 shortblock (4.03" bore x 4.125" stroke)
Cloyes single roller timing chain
Melling 10296 with lower pressure spring
AFR 230v2 62cc heads untouched upgraded 8019 springs
Manton 11/32 pushrods
Custom cam speced by Patrick G 243/247 112+2 HUC lobes
Tuning was also done by Patrick G
FAST 102 ported by Vengeance Racing
Yella Terra rockers
LS9 injectors
ported stock throttle body
Kooks 1.75 headers, no cats
Corsa Sport catback 2.5"
SLP pully
SNL 4" intake with 100mm MAF
255L fuel pump
Compression is 11.65. We are still having some issues with what I think is the rockers hitting the valvecovers. The car stumbles like it is hitting a rev limiter at 5800. It shouldn't be valve float since I'm using good springs and the softer HUC lobes. But is is making some pretty good power until that point. I wanted to build a motor that had good torque in the midrange, fun to drive and to get the heavy goat moving at almost any RPM's. I set out with a goal of 500rwhp and 500rwtq.
I think it turned out pretty good considering the issues still left to fix. And I think I could squeeze out some more with a 102 TB and 1 7/8 headers.
Patrick G was awesome to deal with. Very understanding and went above and beyond trying to get not only a good tune but a really good street manners tune. I would recommend him and Kurt from the shop any day of the week.
Old Dec 19, 2011 | 02:04 PM
ctd's Avatar
ctd
Interesting! I've a 416 with those heads & Fast 102 all modified by Tony. NW 102 TB & AR 1 7/8 catted with a full 3" SW cat back. Nearly the same cam other than 114+2.
How is it around 1600 rpm in the lower gears?
Old Dec 19, 2011 | 02:10 PM
FlamingTA's Avatar
It's really good around town after the tuning.
Old Jan 17, 2012 | 11:18 AM
Spectre86's Avatar
the graph is blocked at my work. What numbers did you do? What were the lift numbers on the cam? stock rear end gear?
Old Jan 18, 2012 | 08:32 AM
FlamingTA's Avatar
521hp and 511tq. lift on the cam was 627int 632exh. The lobes are pretty mild.
Vid that someone took of my car. Just a short idle
Old Jan 18, 2012 | 11:22 AM
redtan's Avatar
Wha do you mean by stock sleeve? Stock ERL sleeve or stock LS2 sleeve?
Old Jan 18, 2012 | 01:15 PM
FlamingTA's Avatar
Stock LS2 sleeve bored to 4.03.
Old Jan 18, 2012 | 01:28 PM
redtan's Avatar
What kinda pistons are you using for the 4.125 stroke on the stock sleeves?
Old Jan 18, 2012 | 01:38 PM
FlamingTA's Avatar
Wiseco. It's a N/A setup that can handle a small shot only. I'm not running FI nor do i plan too so it should work.
Old Jul 2, 2012 | 09:18 PM
FlamingTA's Avatar
Fixed my 5800rpm issue. Replaced my 1 3/4 kooks with some kook's coated 1 3/4-1 7/8 stepped headers and now using a Svede intake.
Old Jul 3, 2012 | 12:57 AM
bamaballa205's Avatar
Stout set-up.
Old Jul 3, 2012 | 08:11 AM
quik01ss's Avatar
Good results but y switch from 1¾ to 1¾-1⅞ stepped....if it were my car id go right to a 1⅞ or even a 2" header
Old Jul 7, 2012 | 12:12 PM
FlamingTA's Avatar
GTO's done have 2" headers, not with out having a custom set made. If i was going all out HP then the 1 7/8 would have been better. There was someone selling the kooks Sig Series stepped headers coated for a good deal so I got them. I would have gained maybe 5hp with the bigger headers at my power level, at the expense of some midrange torque.
Old Jul 9, 2012 | 08:35 PM
STOCK12SECZ's Avatar
What did you do to fix your 5800 RPM issue? Nice numbers!
Old Jul 9, 2012 | 08:41 PM
FlamingTA's Avatar
I think what solved it was shimming the valvesprings. I went thru and measured the installed height on the springs and they were high, 1.825 intake and 1.83 exhaust. So I shimmed them .060" that that took to around @.050 before coil bind.
Old Jul 9, 2012 | 08:44 PM
FlamingTA's Avatar
Oh, and I'm not sure it is 100% solved. I had one dyno run is last time that showed a small dip at 5800 but all the rest were clean. Plus the engine still starts to fall off pretty good at 6000 were it should pull out a bit farther with the HUC lobed cam.
