Sloppy Yank converter? 390 hp A4/can only
So a 390 FWHP car would deliver 374 to the tranny. Minus the loss on the tires and rear end, right? Say about 365ish.
All the newer Yanks, I have ever read about being dynoed, are always above the efficiency rating.
Originally Posted by slow01z28
Jeff I was reading that the pt4000 suppose to have an 96% EFFICIENCY???
If you suppose to then the car would run faster
What do you think?
Rob
What do you think?
Rob
At what RPM is that efficiency rated at? (>6500)
For sure not below 5500rpm.
John
John
John
I am not sure, I am going to cal Mike at Yank today and see what he say's to do with it
Thanks
Rob
Well to let you all know the Converter went bad and took the trans out with it.
I only made 5 runs at the track with it. Getting the tans rebuilt and a new converter now.
Rob
Rob
That sucks. Was the Yank converter under warranty?
John
