here are the absolute/230 numbers....
Is it really on a 110lsa? How is the idle, and driveability?I have that cam on 114lsa, and heads on order from Absolute. I may change to a 112.
Thanks,
Bryan
Thanks,
Bryan
I had that cam on a 110 and it made power to 7100 rpm
We don't want to scare you
I mean even mine on the 112 would probably keep making power past 6,600 but that all I took it too as I have a stock bottom end. Good choice on the 112
Thanks,
Bryan
Here you go... did this today. Car is dirty but it's too damn cold out here to wash the car.
http://www3.sympatico.ca/jim_mills/i...no/112idle.MPG
(Right click and save as)
Thanks for the clip, It sounds really good.
I think I'm going to like it. I know what you mean about being cold, I'm in Michigan. Saturday it was 54, and then on Sunday.....34. Thanks again, I'm really looking forward to my cars transformation. Good luck at the track when you get there!!
Should peak around 6500-6600rpm with ~2-4 degrees ground in
