weakest h/c ever?
Old Mar 25, 2012 | 06:25 PM
butler's Avatar
You will get more from a cam then just heads. Heads are icing on the cake.
Old Mar 25, 2012 | 06:41 PM
smokeshow72's Avatar
yes it was retuned, and the dyno was from the same place
OK, you never know, so I had to ask.
Your numbers do not seem unreasonable to me; honestly, the 430HP claims from a cam and a ported throttle body seem a lot more ridiculous than the numbers you've stated. My car made 263 bone stock with 47K on it and 276 with a mild tune; you are now running 150% of that, normally aspirated, with a driveable car. Not bad at all in my opinion.
C
Old Mar 25, 2012 | 07:41 PM
MikeG's Avatar
Smokeshow, you have some of the lowest dyno numbers I've ever seen for an LS1 car, let alone an M6. Comparing your car to the OP's is not worthwhile. Most six speed LS cars put down 290-310hp in stock form. What numbers is your Z putting down now with the H/C installed?
OP, your numbers aren't that bad. I would honestly be disappointed just like you, but it should still be a quick car! Save for that FAST intake.
Old Mar 25, 2012 | 08:03 PM
Mazzenger's Avatar
A cut-out will help too.
Old Mar 25, 2012 | 08:47 PM
Johnnystock's Avatar
Those big cams like to breath; fast, bigger header or cutout. It would do wonders.
Old Mar 25, 2012 | 08:53 PM
SIC GTO's Avatar
Originally Posted by smokeshow72
On a car that made 270 at the wheels stock? 130 horses with an MS3 and headers? Man, I don't know about that.
This might be a dumb question, but you retuned with the new heads?
Are both dyno numbers from the same place? If not, forget about it; if so, as the other folks have said, dyno numbers are a pretty arbitrary thing. You aren't going to tape your dyno sheet to the windshield; does it FEEL fast? If so, why sweat the dyno sheet?
C
I have a MS3 on stock 241's with longtubes in a 6spd Gto. Stock on a dynojet I made 285, after cam, headers and tune I made 393 on a dynocom dyno which I was told reads about 20rwhp low.
So yeah you can gain 100-120rwhp from cam headers and tune. Basically I make about the same power as the op and I'm a cam only Gto lol these numbers are horrible for having AI 243's. Something has to be wrong...
Old Mar 25, 2012 | 09:28 PM
suvettetexas's Avatar
You are within 5 or 10 hp of mostother cars with similar mods, it could all be in how high the guy on the dyno went with your car rpm wise or maybe could have added a little bit of timing with some race gas like lots of dyno queen guys do, i see them day in and day out at my shop, not too unusual or low, actually seeing one make 430-440 with those mods is on the less common side for a stock block... Hell my car with a decent cam, headers and exhaust only made about 380 and i have access to a dyno whenever i want it, lol... don't be too concerned, just have fun with it...
Old Mar 26, 2012 | 06:45 AM
I am not overly surprised by that; when we pulled my motor out of the car to take it apart we found that the platinum was missing from half of the plugs and one of the plug wires had damned near arced through which was certainly causing some misfire. The car drove fine when I got it, but obviously had not been particularly well maintained by the previous owner(s). Even with all of that, I am sure I could've dyno shopped and pulled 290 if it was important.
I have not pulled the car on the dyno since the headwork and cam because I frankly don't have the time or the money right now for a dyno tune, but I expect to do so in the next couple of months; I'll be interested to see what the car does now that it is properly maintained. I know that it spins the 315 rear tires at 4000 in first gear with 3.42s after grannying out of the hole, so it is doing OK...
C
Old Mar 26, 2012 | 01:48 PM
00silverGTP's Avatar
thanks for the comments guys. I guess spending $1200 and only gaining 30 wheel is a little disappointing. but I am putting it to the test tonight racing a c6 that has raced many other h/c cars. so we will see.
Old Mar 26, 2012 | 01:53 PM
senicalj4579's Avatar
Forget the #s for now and take it to the track and see what it does.
Old Mar 26, 2012 | 02:03 PM
FBGSU02's Avatar
I put down 415 rwhp with the MS3 cam only. But like they say take it to the track, dynos are for tuning and tracks are for racing. An E/T means more than rwhp to me.
But in my sig I put the gains i received from different mods.
Old Mar 26, 2012 | 03:45 PM
  #32
MikeWS6's Avatar
Like others have said I wouldnt worry about the numbers too much.
Old Mar 26, 2012 | 07:02 PM
  #33
yeah. I just raced a c6 that has beaten 4 h/c ls1s. only lost by about a car. so I am happy with it. check out the video in the kills section here soon.
Old Mar 26, 2012 | 09:29 PM
  #34
Very cool !! I'd be happy with that for sure.
Old Mar 26, 2012 | 11:43 PM
  #35
01ssreda4's Avatar
Bone stock auto cars usually dyno around 300 and M6s usually can hit 310 to the wheels. Lots of cam/bolt ons only cars dyno 400.....I'd be interested to see the graph on this one.
Old Mar 27, 2012 | 08:40 AM
  #36
Interesting that so many cars that were rated at 300 or 310 crank horsepower SAE are making 310 to the wheels twelve years later.
I had an 350ish crank horsepower small Chevy in a pickup in high school and a shiny new 2001 Z28 M6 a few years later. Unless my truck was really making 400, The Z28 was not a 350 horsepower car, which it would have to be to put 310 to the wheels.
After reading this thread, I now have even less faith in chassis dynos than I had before I bought this car. I'll still dyno tune the car so we know it is running properly at WOT, but methinks the power numbers will be pretty arbitrary. It puts a smile on my face when I get on it; that's all that truly matters in the end!
C
Old Mar 27, 2012 | 08:58 AM
  #37
01ssreda4's Avatar
Your 2001 Z28 absolutely was a 350 hp car on an engine dyno. It probably didn't feel like it because of the stupid long winded gearing they put in the M6s.
Old Mar 29, 2012 | 07:34 AM
  #38
TORK?'s Avatar
Does it run good and pull hard? That's all that matters. My old 99 Trans Am put 303 to the wheels through an unlocked converter and would go 90mph in the 1/8th with 1.5x 60's.
If I was you, I'd just tell people it's making around 400 and then go out and show them your taillights.
Old Mar 29, 2012 | 08:44 AM
  #39
thunderstruck507's Avatar
If you poke around and do some research you will find the ls1 is a roughly 345hp engine. There is zero meaningful difference between the fbody ls1 and the Corvette ls1 other than the window sticker claiming the corvette made 340hp while the Camaro made 300/305/315. The Camaro/Firebirds were just severely underrated by GM.
Old Mar 29, 2012 | 09:45 AM
  #40
bww3588's Avatar
dont feel bad Eric, my car only did 367 on an MS4 and TSP 2.5 5.3 heads.
