weakest h/c ever?
ms3
p/p tb
lid
headers, ory, hooker catback
415/380
I only picked up 30rwhp going from 853 heads to the ported 243s....I was hoping for 430 with this setup.
What tires, gear, wheels, MAF, trans, flywheel?
What kind of dyno? What was the WOT AFR and timing?
**** dyno numbers, they can be all over the place. Take it to the track and see what it traps, assuming its tuned properly.
42lbs
AI states 20-30 wheel gain from the port. And going from the 853 head to the 243 I was just expecting to make more I guess. I understand the dyno is just a tool...
42lbs
no I have a IAT mod to pull the timing. Car made 518/500 on the 100 shot.
But I dont care cause my weak H/C/I is capable of 117-119 on the 1/4..
This might be a dumb question, but you retuned with the new heads?
Are both dyno numbers from the same place? If not, forget about it; if so, as the other folks have said, dyno numbers are a pretty arbitrary thing. You aren't going to tape your dyno sheet to the windshield; does it FEEL fast? If so, why sweat the dyno sheet?
C
C
I have a timing box for my spray....
I had a 346 stock bottom end ls6 intake, full boltons, stock rear 3.90 gear locked 4l60e converter(4000), TSP ported LS6 heads, 235/243 cam
My car is full weight and I weighed(Well back then lol about 210 lbs) and it would trap 113 - 115mph all day long.
http://i752.photobucket.com/albums/x...4/DSCN0932.jpg
