TSP H/C Build 470WHP
Old 08-21-2012, 09:32 PM
LS1T56FTW's Avatar
Originally Posted by chevybayboy
What setup you running
Go to my build thread at the top of the page.
Old 08-23-2012, 09:23 AM
fastvet's Avatar
That is pretty impressive. Your video says final pull, and at the end it shows 377rwtq. where did u come up with the 419? Most people pull 440rwhp with that setup, idk what u did, but it worked!
Old 08-23-2012, 10:02 AM
thunderstruck507's Avatar
A lot can change in 3-4 months with a dyno. My car magically lost 20+rwhp in 3-4 months on the same dyno in OKC. But it also ran .2 and 1.5 mph faster.
Either way it is a stout combo and looks to be making more than the typical 440 range for the setup, but 470 is a little optimistic IMO. I would be thrilled as **** with those results for the combo you put together. Post up some track times when you go, I bet it runs well.
Old 08-23-2012, 11:42 AM
LS1T56FTW's Avatar
It is making 377 torque at 7000 RPMs. It makes 419 at around 5000 (if I recall correctly) - that is what those numbers in the middle of the graph are for.
Old 09-04-2012, 06:29 AM
TransAmcoupe98's Avatar
Those are extremely high numbers lol. In for track times for confirmation.
Old 09-12-2012, 11:30 AM
LS1T56FTW's Avatar
I am going to need a lot more practice to dial the car in, but currently I am trapping a hair under 95MPH in the 1/8th mile. This is with my shift light set at 6400RPM. I am probably going to raise it up a hair eventually.
Old 09-12-2012, 02:09 PM
s346k's Avatar
Originally Posted by NW Iowa WS6
About 120mph with 1000-2000 density altitude should be about where your at if it has that much power.
i'd be expecting a lot more than that. a local made 406 with a cammed ls1 and trapped 118 in a full weight car with a da hovering around 1k'.
Old 09-12-2012, 05:51 PM
1989GTA's Avatar
"This is with my shift light set at 6400RPM. I am probably going to raise it up a hair eventually."
So you are probably shifting around 6500 rpm. Going by your graph I would up that somewhere between 1K and 2k rpm.
Old 09-12-2012, 06:22 PM
HCI2000SS's Avatar
Wow..very impressive for sure! I just got my SS about a week ago, and it has a very similar build to yours. The guy said it made 460 on the dyno of a place that is now out of business, so i'm gonna throw it to my former tuner and have him dyno just to confirm, power, a/f, etc...Hope it's similar to yours
Old 09-13-2012, 02:16 PM
IllusionalTA's Avatar
Sad to see all the naysayers.. Congrats on your cars performance, hope you really enjoy it!
Old 09-13-2012, 06:03 PM
LS1T56FTW's Avatar
Proof that you don't need to blow your budget and still make great power, right!?
The car is an absolute rocket so far. I plan on installing a FAST intake next spring too. That would be insane if I could break 500whp, but I highly doubt it would make much more than 490, if that, with a FAST.
Old 09-13-2012, 06:21 PM
  #32
You never know , my cam only lq9 made 50 more then I thought it would.. Anything a possible
Old 09-19-2012, 04:34 PM
  #33
mikesanto70's Avatar
1/4 mile times and trap please!!!!! :-)
Old 09-20-2012, 02:53 AM
  #34
MikeWS6's Avatar
Those numbers are just crazy high. My car with those heads wouldnt even come close.
Old 09-21-2012, 07:09 PM
  #35
PewterScreaminMach's Avatar
Nice man. Curious to see how it runs once you get it dialed it. My 02 Z28 was 3500 lbs without me in it and made 408/380 SAE on a Dynojet. In a similar to higher DA, it would trap about 92 in the 1/8 and in a negative DA it would do 94, so I would have guessed yours would be in the 440ish range on the same dyno based on your current numbers. I probably would have guessed similar or slightly lower just based on the setup before seeing any numbers.
Old 09-23-2012, 08:02 PM
  #36
LS1T56FTW's Avatar
I was 0.09 MPH away from trapping 98 today and I still have room to grow, so...yeah.
Track times:
https://ls1tech.com/forums/11-second...l#post16749792
Quick Reply: TSP H/C Build 470WHP
