LS6 to Fast 102
Old Oct 24, 2012 | 12:38 PM
99creelz's Avatar
Default LS6 to Fast 102
Just got my car dynoed and tuned by Alvin at PCMforless. I went from a ls6 to fast 102 picked up 17hp.Car made 461hp 405tq. Before it made 444/428.Numbers are SAE. I also changed to a CME setup with Borla exhaust from true duals and went from 3.73 to 4.10 gears so the number would have been higher.I have an MTI 78mm clear lid that might be holding me back some too.
Old Oct 24, 2012 | 12:58 PM
raysadude's Avatar
Nice gain! Swap that lid with ftp 98mm and add chrs1313 ram air + 85mm MAF if you dont already have one and expect to gain at least another 5rwhp and more on the highway
Old Oct 24, 2012 | 01:00 PM
raysadude's Avatar
Oh what size TB do you have out of curiosity?
Old Oct 24, 2012 | 02:13 PM
99creelz's Avatar
BBK 100mm
Old Oct 24, 2012 | 05:33 PM
raysadude's Avatar
I see, glad to see you get good amount of gain with the intake man!
raysadude's Avatar
Any graph?
Old Oct 24, 2012 | 06:45 PM
Johnnystock's Avatar
Cam spec?..Very good numbers on the ole LS1!
Old Oct 24, 2012 | 07:17 PM
99creelz's Avatar
Thanks guys. I tried to post a graph but it didn't work. I'll try again. Specs are 230/236 605/613
Old Oct 24, 2012 | 11:25 PM
_GTO_'s Avatar
Is it normal to lose that much torque when having higher gears ? Or that just because of the fast or something else .
Great numbers BTW .
Old Oct 25, 2012 | 09:37 PM
Philip Pugeau's Avatar
The torque loss is from the cam changing the powerband. It becomes more efficient at high rpm, which makes more hp over torque. It probably has somewhere around a 112 LSA. On that setup, the fun begins at 5000 rpm!
_________________________________
2001 NBM Formula A4 T-Top DailyDriver
383ci b&b | 230/236 114+4 | AR 1-3/4" LT | AR 3" Y-pipe | FTI 3500 | Built 4L60E | BMR k-member | BMR F&R U&L control arms | torquearm | panhard | PST 3.5' | S60 4.10 | 315/35R17 555R
393rwhp / 377rwtq
Old Oct 26, 2012 | 02:16 AM
bww3588's Avatar
Very nice, what heads are you running?
Old Oct 26, 2012 | 11:36 AM
99creelz's Avatar
TEA stage 1.5 5.3 heads.
