Newb Here - 1st Post
I'm assuming the published numbers are with 93 octane, and if I further assume 15% driveline loss, that will leave me at approx. 408/404 at the wheels using the published output at the crank. What I'm wondering is this: if I run 87 octane, what is the percentage rear wheel output loss I'm likely to see? Experience with BMW motors tells me it's right around 2% (i.e., I'd have around 398/394 at the wheels after going to 87 octane).
More generally, what is the convention for reducing the output of these motors? Can it be tuned out? Intake restrictor plates? Any help will be most appreciated.
Good point re: where to start. I just ran down the crate motor catalog & picked out the LS3 "hot cam" unit as the best place to start. Probably should have asked for advice first, huh? lol
I've seen that. I'm afraid the cost of these crate motors has left me like a kid in a candy store - the price per HP when comparing a standard LS3 with one that has the hot cam makes me want the one with more HP because it's so damn cheap compared to adding power to a BMW motor. Even though the cost difference is small, maybe I should just focus in on the motor that gets me what I need now, knowing that modding it later has a relatively modest cost to it.
6.0/4l80e can be had cheap as well...hell even a pullout ls2 out of a gto with a trans and all the accesorys/harness is like 3k cheaper than that ls3 crate...and you get a lot more...
