You will not believe this...
I am at 4,000 elevation and run 13.5s up here (mid to low 12s at sea level) at this elevation (stock ls1s run high 14s here). I went to go get the car dynoed today and guess what i put down? You will not believe it....
A whopping 149rwhp.... Thats right. I told the guy that was way off than what it is suppose to be and he kept on insisting to me that it was right and kept trying to sell me one of his dyno tunes. He ran my car 2 more times and got just about the same numbers.... Then he told me that it was dynoing less cause the car was hot (even though it was like 60 degrees outside). And engine heat cannot possibly cause the engine to lose like 180 hp lol.
Here's the catch. Back when i was stock, i got the car dynoed and it made 290rwhp on that same exact dyno. I told this guy that but he just kept on insisting that i needed a dyno tune from them and it'll make me regain all that loss hp. Nonetheless i am never going back there again. Just needed to rant a little bit....
Someone should be able to use LS1edit or HPtuners to find out whats causing the problem.
I was once at El Paso... FT Bliss, Chicos TACOS!!!
My car dead stock(almost is still)made 292hp and 319ft/lbs if I remember correctly and with a lid and GMMG catback(no dyno) I have run a best of 13.74...sounds like your being screwed man.
There are things being done to remedy the tuning problem in El Paso and shop problem. Hoping the coming year.
