help with set up
Old Dec 28, 2012 | 01:13 AM
lowrolr's Avatar
Default help with set up
I have a 5.3 bored to 3.898 with minor ported 243 heads. Using performace products typhoon intake debured cleaned up runners. 85mm throttle body. Ls6 water pump tsp torqer v2 camshaft 112 lsa or possably 228r. Ls7 lifters and 1.7 rockers. Short tubes. Will love good or bad opinions exepted.trans is 4l60 trans 3600 stall. Gears any where from 3.42 -4.10s will be in 01 blazer approximately 3800lbs. Will take positive or negative advise. Truck will see street and strip time. Any help will be greatly appreciated. Thank you
