Turbo 5.4L with LS3 heads, 16 psi, 992hp/798tq video
Stock LS3 rockers. I got the crank off eBay. I have another if you are interested in one, fresh .010/.010 grind and polish.
The shortblock should have just as good of longevity or better than most engines for the reasons I listed in my previous post. The valvetrain is a little aggressive, and high spring pressure for stock rockers. Better heads and roller rockers will be in the future, most likely will go solid roller at that time as well. But for now it will run just fine for what I'm doing. I'm also going to buy a vacuum pump when it goes in the car.
I learned a lot just from you explaining about the destroked engine, I'm pretty sold on having one built. But I think I may go with an ls9 cam. I wish I knew more about engine combos.
Not sure if this link will work since it's on his facebook page.. But Jakson stuck the car on the dyno up here at carcraft last weekend.
https://www.facebook.com/photo.php?v=10200191608014195
811rwhp, 679rwtq. On only 15psi of boost.
You can't even hardly hear the setup. This car is a sleeper for sure.
#34
Thanks for posting up the link Zach. Heres the youtube link incase the FB one didn't work for anyone. Certainly surprised a few people, like he mentioned, the turbo isn't noticeable at all until its in boost. Most the people walking by it with the hood up didn't even notice the turbo, its tucked down nice and out of sight.
Timing is at 19 degrees conservatively right now. This was just a base tune made up on the street the night before, so I could throw it on the dyno at the show! I believe the most we put to it on the engine dyno was 21 degrees.
The exhaust setup is a 4" downpipe necked to a 3.5" cutout, necked down again to a 3" two on the left muffler. On the dyno it was open cutout, the in car footage was closed through the muffler. I'm thinking I want to go 4" all the way back with it over winter, it's a little to raspy through the muffler for my taste, have to let it breathe a little!
#36
Large bore/short stroke/ long rod engines are a common place in the SBC world. I wondered when the combinations were going to start hitting the LSx motors...especially for boosted applications. I thought when Hot Rod Magazine did it's 4.8 budget turbo build, the next thought progression would be motor combinations exactly like this. Fantastic job!!
#38
