NA 4.8 potential
I've got an 03 reg cab short bed silverado that could use some pep. I don't plan on ever racing, or hoping that its fast, but I don't want to invest a bunch of money if it won't break 400whp.
Thanks
hot rod made 451 flywheel hp on an engine dyno. would probably be 370-380 whp on a chassis dyno with a 6 speed/10 bolt F-body.
not many people build 4.8s for NA power.
So 451fwp with just ported stock heads, fast, and a cam. Granted the peak was 7000rpm, which I don't want. I'm sure that's from their cam and intake choice. I would suspect an NA combo to make less peak and more average than that, but its a good idea of what's possible.
Do I have to worry about the stock 4l60e or whatever the stock trans is called, at these power levels?
a GOOD transmission builder will be able to keep a 4L60E alive easily behind a H/C 4.8L.
4.8s just lack cubic inches, so power can be made, but typically (due to the shorter stroke), it will be a much higer rpm that necessary (also causing parts to wear much faster - power doesn't kill motors, rpm does). A 5000lb truck with a stock 4l60e (and matching 4000 stall to get the turd to move), is going to generate a lot of heat and fatigue parts prematurely.
The easiest way to make N/A power, however cliche', is displacement.
an LQ4 with a box stock Ls3 intake and L92 heads with the shittiest cam you can throw at it will make over 400whp. Put a decent grind and watch the intake valve overlap (monster intake valves do not need to be open nearly as long as say an 862, 706 head tiny intake valve will) and it will make north of 450whp or more.
So spend $$$$$$$$$$$$, wear out parts quickly, and be stuck with no more room to grow.. or find a couple hundred dollar short block, throw some cheap heads on it, and watch it fly.
..or..
Boost.
have fun. If you decide to build the 4.8.. it would be entertain to see how much could be made!
I stand corrected.
I was thinking the stroke was the same but the bore was smaller. I had it backwards.
EDIT: the 5.7 being the ls1. Yes its aluminum but its the same block casting so everything bolts up.
Are there any oem cranks and rods that can be mixed and matched to create a budget stroker kit? Or just aftermarket?
As for the blocks, I know exterior wise they are all basically the same but inside they might be different. Im not sure if you can bore a 4.8 block as far as you can a 6.0. Maybe someone else will chime in.....
I believe he still messed around more with the setup and the 4.8, but as far as bonestock 4.8 on a (P1SC) centrifugal supercharger he did a 12.66 at the 1/4 mile at 6pounds of boost.
Here a vid:
