MS4 LS1 vs MS4 6.0
I've since changed my setup to a less radical one but I'm still curious about the dyno results and why. My friend and I both had ms4's in our cars with slightly different setups but almost identical results. My car had the 6.0 his had the LS1. Below are the mods for both motors. Also, both cars were dyno tuned at the same place and same tuner. My questions is do you think my exhaust held me back.
LS1: Stock cubes/bottom end
stock 241's
LS6 intake, 80mm tb
MS4 cam, 7.400 pushrods
42lb injectors
TSP 2" primary headers
TSP true duals
racetronix fp
Results: 409rwhp, 383rwtq
6.0: Stock cubes, forged internals
stock 243's
LS6 intake, 80mm tb
42lb injectors
Kooks 1 3/4 primary headers
Kooks y(crappy merge) GMMG catback
racetronix fp
Results: 409rwhp, 399rwtq
Like I said earlier I went to a less radical setup, smaller cam and 317's for boost, but I'm soon installing my EPP blower cam so hopefully I'll be back in the 400hp range. I've also upgraded to 1 7/8 headers and true duals. I'm just asking because it's something I've been trying to figure out.
stock 241's
LS6 intake, 80mm tb
42lb injectors
TSP true duals
racetronix fp
stock 243's
LS6 intake, 80mm tb
42lb injectors
racetronix fp
He has 2" primaries vs. your 1 3/4s.
Also, what is the 6.0's compression vs his?
Did you get them dyno'd on the same day at the same time?
What is the drivetrain behind the engine? Tranny...rear end...axles...wheels/tires?
That all can make a difference in the dyno results.
I think the exhaust def held you back. The cam and ls motor in general love big headers. Also the weather on both days could have been different. Are you both 6 speeds or autos and what rear is in each car. All the little things by themselves dont really make a difference minus the exhaust, but add them all up and theres your answer most likely
I'm assuming both had same rear and Trans with similar weather. Only thing I think that could had affected that was your 1 3/4 vs his 2" headers. Not to mention he has true duals vs your y-pipe. Anything else could be octane that both of u all were using. Idk. It's a good question.
Could be a lot of things, but it sounds like you are expecting the cubes to make up for the power and that's not usually the case from what I've seen. Given the same cam/intake/etc the bigger motor will make more torque but similar power just at a lower RPM.
That's why personally I wouldn't trade for the iron block unless it was a bigger cube stroker with a more aggressive cam/head setup to take advantage of the bigger engine (the exception being stock engine is blown and the block is trashed)
stock 241's
LS6 intake, 80mm tb
42lb injectors
TSP true duals
racetronix fp
stock 243's
LS6 intake, 80mm tb
42lb injectors
racetronix fp
stock 241's
LS6 intake, 80mm tb
42lb injectors
TSP true duals
racetronix fp
stock 243's
LS6 intake, 80mm tb
42lb injectors
racetronix fp
my tuner regularly tunes ms4 cars that make 440's through a 6 speed with your mods. I'll be interested to see your dyno with your EPP cam. It may be worth contacting my tuner if our numbers vary significantly.
My epp blower cam made 422 rwhp 392 rwtq with stock injectors, ls6 heads, ls6 intake, long tubes (1"3/4), a lid w/ k&n, t56 trans, stock 3.42 gears.
LS6 Camaro with EPP Blower cam on the dyno 2nd pull - YouTube
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Exhaust definitely could have robbed some power. Im assuming you have dished pistons? That could rob a few HP too because of lower compression.
You have to remember that the dyno is just a tool. My 98' in my sig dyno'd 405rwhp (granted its an auto). But a real test would be a race between you two, especially if you have really close race weights.
Super Hulk Smash
Means the exhaust is the likely culprit. And also variation car to car.
