Fast 92 Swap Results - A4 '02 Z28
I support the different dynos being off however the rotating weight is moot imo. I have never seen a car dyno higher with a lightened flywheel or lighter clutch op is an auto but the principle applies, also when a car is dynoed with a high stall converter it usually loses power due to it being unlocked. in cases where they are both locked I have never seen a large difference on the dyno regardless of weight of the converter.
Now I do think 20whp is a bit much on a totally stock internal ls1. But I have seen fasts make 15whp more or so on a stock internal ls6 motor over an ls6 intake which is what I'm going for but I would expect around 10 on an ls1 but again thats a guess.
i put AFR 1510 heads, comp 224/230 .581/.592 114lsa, on stock LS1. A guy at AFR said stay with the FAST 92 over the 102. Guy at FAST said use the 102. Is that too much for my set up? ive gotin mixed answers so far. Any input from dyno tests would help. i gota buy an intake and tb asap.
