Granatelli Wires vs Stock Wires
Old 04-29-2013 | 12:00 PM
  #41
granatelli sales's Avatar
Originally Posted by LS6427
Which wires, the Granitelli ones broke and the clamp stayed on the spark plug???
If you ever have the clamp come out of the boot problem Call Granatelli Motor Sports and we will replace the wire when the old one is sent back
Old 04-29-2013 | 12:42 PM
  #42
Redbull87's Avatar
I reclamped mine back on and needed the my car running that day but if it happens again ill send them back. Still a great product.
Old 04-30-2013 | 10:34 AM
  #43
Gordon0652's Avatar
Very impressive!!! VERY!
Old 05-01-2013 | 09:03 PM
  #44
Originally Posted by blazzin1
They're perfect. they are the best wires you can get!!! No regrets here!
people are happy with what the wires do
Old 05-01-2013 | 09:43 PM
  #45
1989GTA's Avatar
What set of spark plug wires would you recommend for a L92/L99/LS3 motor?
Need a part number. Car does have headers and appears there is plenty of clearance.
Old 05-01-2013 | 11:20 PM
  #46
djfury05's Avatar
Since I asked for an outside party for a back to back NA test I've received a few PM's that had done some tests stating they didn't gain anything. No other changes except for the wires. So I guess I won't be getting a set.
Old 05-01-2013 | 11:54 PM
  #47
therabidweasel's Avatar
If they are well made, stand up to heat well, and warrantied well why not buy them? I still believe any difference would probably be timing related, but same performance with the above is still worth buying imo.
Old 05-02-2013 | 07:42 AM
  #48
maxpower_454's Avatar
A well documented NA test would be great since turbo'ed LS's are by far the exception not the norm. Still really impressive video! Although MSD's are 50 OHM's per ft (equating to about 10-15 OHMS in a LS1 wire) and MUCH cheaper.
Old 05-03-2013 | 01:13 PM
  #49
can you send pm me the dyno sheets
Old 06-27-2013 | 09:33 PM
  #50
LIL SS's Avatar
Moderator
After pull 9 I decided the AFR and Timing looked good. No other changes I swapped from a stock wire to a set of Granatelli's. Only reason I bought them was the have a warranty and the burn resistant fabric. Son of a gun.. AFR staid the same, timing staid the same.
Old 06-27-2013 | 10:01 PM
  #51
1989GTA's Avatar
Having a hard time reading the numbers on the chart. Did you pick up around 15HP with the Granatelli spark plug wires?
By the way with my build I went ahead and purchased the Granatelli wires. I have one issue to resolve before I can even thank about making any dyno runs.
Old 06-27-2013 | 10:10 PM
  #52
john563's Avatar
huh?! i might have to get a set..i out down 435ish in an A4 wonder what id gain..either way id buy..i nean hows the sayin go "put up or shut up" he def put up and proved his product..whats part number for a 98 ls1
Old 06-28-2013 | 01:13 AM
  #53
LIL SS's Avatar
Moderator
I gained 19rwhp at peak but as muc as 25rwhp bellow the curve. I was not expecting anything to tell you the truth. Could be my stock wires were junk. Dunno, just showing my back to back gains.
Old 06-28-2013 | 01:37 AM
  #54
LilJayV10's Avatar
That's great to hear Lil SS. I didn't see any gains going from MSD wires to the gran's.
Old 06-28-2013 | 09:45 AM
  #55
djfury05's Avatar
Yes stock wires are junk. Lots of resistance.
Old 06-28-2013 | 01:55 PM
  #56
1989GTA's Avatar
That is interesting with some good results. I hope I can see those gains on my motor.
Old 06-29-2013 | 09:34 PM
  #57
dr_whigham's Avatar
The Scammer Hammer
Pardon my French, but holy ******* ****.
Seriously?
My MSD's are 3 years old and have come off at LEAST 5 times I'm aware of. I very well may be picking up a set of these.
Even 6hp/4ftlbs would be great to me.
Old 06-30-2013 | 12:13 AM
  #58
djfury05's Avatar
Seriously?
Read post #54.. I went with Firecore50 wires myself. If most all the fastest guys prefer Firecore50 wires and they get nothing but good reviews that's good enough for me to use them. Do a search on the bullet for them.
Old 06-30-2013 | 12:33 PM
  #59
dr_whigham's Avatar
The Scammer Hammer
JakeFusion went with those as well.
I'll jump on YB and look around.
I do like the fact about the warranty...
Old 06-30-2013 | 07:06 PM
  #60
miami993c297's Avatar
Agree...
Christian
Quick Reply: Granatelli Wires vs Stock Wires
