Expected 383 Stroker Dyno Numbers?
Old May 16, 2013 | 01:19 PM
PsychoMoongoose's Avatar
Default Expected 383 Stroker Dyno Numbers?
Hey Guys,
Getting a little ahead of myself, I would like to ask you guys if you can ballpark what you think the dyno should say at the rear wheels. It will be all together next month, and hopefully a TON of FUN!
I have an LS1 with an Eagle stroker crank, Eagle featherlight rods, and Mahle pistons. It has Brian Tooley Patriot springs with titanium retainers, Manley pushrods, and a 3726R/3729R HR111 232d/238d .595"/.605" 111LSA Comp Cam, stock rockers with upgraded Trunnions, LS6 intake, 1 3/4 OD ceramic long tube headers, however it has STOCK LS1 heads that have been port matched. Stock throttle body. 4.08 final drive. Aluminum driveshaft. Light flywheel, cant remember what the weight was. The PCM will be tuned for the upgrades.
Thank you in advance for anyone with some insight!!!
Old May 16, 2013 | 02:02 PM
Gabbiani's Avatar
With the stock heads it will be torquey but not crazy on the top end. Pretty much a guess I'm thinking 410hp/450tq. Get some heads on it.
Old May 16, 2013 | 02:07 PM
moeZ28's Avatar
Not a chance itll hit 450rwtq with stock heads...410rwhp is a good guess though.
I'll say 412rwhp/388 rwtq. The stock heads are gonna hold you back!
Old May 16, 2013 | 02:11 PM
Gabbiani's Avatar
My guess-o-meter can be off sometimes. On second thought moe is closer. Either way broad flat torque falling off early.
Old May 16, 2013 | 02:15 PM
SSdreamz's Avatar
Old May 16, 2013 | 04:13 PM
Killer5.3's Avatar
Old May 16, 2013 | 04:34 PM
Thanks for the input guys!
I will post dyno results as soon as I can get them!
How about with a set of Trick Flow 255s? What do you guys think the numbers might be with a set of those on there?
Old May 16, 2013 | 06:01 PM
moeZ28's Avatar
If your talking about TF's new LS3/L92 heads, you would need a 4" bore at minimum to run those heads...
Old May 16, 2013 | 06:31 PM
MoeZ28, these are what the guy at Trick Flow recommended to me with the setup I have.
http://www.trickflow.com/partdetail....2&autoview=sku
Do you see a discrepancy with my setup and these heads?
Thanks again for the input man, i really appreciate the help.
Old May 16, 2013 | 06:58 PM
moeZ28's Avatar
Nope, those TF heads kick *** man...if you can afford them get them.
