SNS stage three now with track results(9/7)
Im whoring this out because I had such a hard time finding results with this cam. I am very happy with it, would love to see it with a nicer set of heads now.
Build is fast 92/92, factory 243 heads, SNS 3, 1 7/8 headers, and an under drive pulley. pretty simple.![](http://i298.photobucket.com/albums/mm262/minisz618/Scan4_zps7fbb9f65.jpg)
And the car.
And the car.
![](http://i298.photobucket.com/albums/mm262/minisz618/IMAG0320_zpsd6ed2d16.jpg)
Thanks everyone! very effective for the simplicity of the build. So much torque
I don't really know what I will do with heads, I want to drive it as is until I break the rear end, then I will get a 12 bolt with some 4 10s loose the 28" tire for a 26". then drive it some more. I have not even thought about heads yet. But if I were held at gun point I would probably get AFR 210s
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Seeing this makes me wish I'd have gone with the SNS Stage 3 over the SNS Stage 2, which I currently have. That torque curve is amazing for a bigger cam. I'd love to see what the SNS Stage 3 would do with my AI Dart/RHS CNC'd heads.
Also, how is it with the 28" tall tires? I assume you're a M6, correct. Reason I ask is because I had the toughest time deciding between a 26" or 28" tall tire for my Dark Star wheels. I wanted a big, wide ***, tire on the back and really wanted to go with a 325/50/15 (28"), but ended up going the 275/50/15 (26") route. I figured if I did that, I wouldn't have ABS issues and it would be better for my stock 3.42 gears.
I just have the 28" tires because I bought them used with the tires. I will be getting 26" once i burn through these. It still has the stock gears in it too. I don't want to put money into a rear end that is going to break. It is an M6. It drives very well with the tires and low gear, but that's to me I don't know any different, Im sure once I get the 12 bolt with 4 10s and 26" tires it will be a different car again.
As for going with the stage 3 over the stage 2 after being recommended the stage 2 was that I wanted to be different (have not yet seen much in results) and I had a feeling we would see alot of cam only stage 2s.
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
It is pretty good to tell you the truth, The car does not like being below 1500 rpm but it does it without bucking. (i usually keep it around 2000)
I do but my pocket book still says no. haha
