gear loss ??
Old Aug 31, 2013 | 03:21 AM
LSOHOLIC's Avatar
Default gear loss ??
I will be the first one to admit I do not know a lot about dyno stats.......
So the question is about gear loss on the dyno. How much lower (if any) does a 4.10 show vs 3.42 ?? Does the type of dyno influence the numbers that the gear (eats) makes ??
Ive talked to a few operators and some say their dyno (dynamics) shows no difference in gear choice and others (dynojet) say a 4.10 will be down on power "on the dyno" anywhere from 4-7%
Have any of you done back to back dyno pulls after a gear change ?
Old Sep 1, 2013 | 10:08 AM
HolyShiznit's Avatar
Went from 3.42 to 3.90's on my Vette. DynoJet, went from 470ish to 456. Roughly the same air each day.
Old Sep 1, 2013 | 12:48 PM
LSOHOLIC's Avatar
So that roughly 3%.....not to bad. I have read that it is not always the same % and with higher hp builds the % can increase.
