Extensively modified TF 235 results
Old Sep 21, 2013 | 11:31 AM
Rise of the Phoenix's Avatar
Originally Posted by dr_whigham
With my AFR's I'm almost at the point of diminishing returns. The money can be more appropriately allocated towards his TFS casting; coupled with larger lighter valves, custom chamber work, hand finishing...
It's just nice that a guy that works with some of the biggest names in racing picked up the phone and had a conversation with little ole me, if that makes sense.
Sounds like you've made up your mind then, huh Dave? What type of intake setup are you going to run if you go this route? You given any thought about a Super Victor or Victor Jr. setup?
Old Sep 21, 2013 | 12:45 PM
weldermike27408's Avatar
PM sent to NASTE SS re: heads
Old Sep 21, 2013 | 03:23 PM
That goes a long way in my opinion
Old Sep 22, 2013 | 08:33 AM
muttstang's Avatar
Holy ****...so ls3 stroker is what?? 416...42x...I'm not familiar with them.
Crazy gains though...kinda makes me wish I woulda got my afr 230s worked over :/
Old Sep 22, 2013 | 09:29 AM
ctd's Avatar
ctd
LS3 stroker is a 416 stock bore.
The very best I could do with claimed ported AFR 230's 518 RW, that was with two different camshaft's. The first was a non tunable 243/247 114+2 unbearable POS, the second as it is now.
Old Sep 22, 2013 | 09:56 AM
(SS)'s Avatar
Just when i was leaning toward AI i read this
Old Sep 22, 2013 | 07:12 PM
I'm wanting to do a head swap only .... pretty happy with how my 243's are performing but Ive been thinking about Trick Flows for a while ... If I have to change my cam too Ill just keep my set up as-is
Old Sep 24, 2013 | 12:21 PM
quik01ss's Avatar
I neeeeed a set of these!!!!!! Awesome results
Old Sep 24, 2013 | 06:07 PM
muttstang's Avatar
Wow really?? I figured they'd run just as good if not better than the 235 trickflows
Old Sep 26, 2013 | 07:59 AM
ctd's Avatar
ctd
I had goals & objectives, as you did when I look at your profile. You exceeded yours, you should be happy with that. When mine was dyno'd initially I was told 539 RW, my goal was 550. After picking up the car I stopped @ another shop on the way home to verify the numbers, 518 RW. Another dyno after I got home 518 RW hmmmmmm. These were supposedly not off the shelf AFR 230's, nor an off the shelf FAST 102. Full 3" exhaust, large Z06 LS7 CAI blah blah.
Old Sep 26, 2013 | 08:44 AM
I'm just glad you got with someone who's well respected and really knows what he's doing in regards to head porting and proves that the money you spend with him is money well spent, which can't be said about everyone out there who hand ports heads. The back to back results speak for itself.
Old Sep 26, 2013 | 01:41 PM
  #32
muttstang's Avatar
Yea you're right...well you sure as hell got it figured out now haha
